Old 01-27-2013, 06:10 AM   #1
Noskipallwd
Default Torque tube conversion
Hello, I am assembling the Align 500 TT conversion kit, and have confused myself(not hard to do!). I have a couple of questions for anyone who has assembled the kit. The instructions state to install the TT bearing off of center. How is this oriented? For example, shorter piece towards the main gear and longer torwards the tail, or vice versa. Also which side of the bearing does the TT bearing holder go? Same as above, main gear side or rotor side. Thxs for any help.
Cheers,
Shawn
Mcpx v2, Nano CPX, V911, Mini CP, Master CP, HM Axe CP, Axe 100 CP, 1SQ, Trex 100x, 250 Pro DFC, Trex 500e(stubbornly still FB) T8FG, DX7S, Devo 10
Noskipallwd is offline        Reply With Quote
Old 01-27-2013, 07:24 AM   #2
Geardaddy
Hey..
You want to find the center point of the torque tube.. then VERY carefully glue the bearing to the torque tube approx 2cm off from center.. Then the end of the torque tube that is 'shorter' relative to the bearing placement will go towards the boom block.. Longer end towards the tail..
The rubber bearing holder.. It doesn't go next to the bearing.. It goes OVER it.. the bearing will sit inside of that rubber housing.. Be really careful when gluing that bearing.. The best way to do it is put a very small amount of thin CA onto a QTip, and then run the qtip around the torque tube where you want the bearing.. If you put too much on (super easy to do) then when you slide the bearing into place, it will create a 'wave' of ca which will spill into the bearing.. At which point.. your bearing will be toast.. Ask me how I know..
GD
TRex 700DFC CC 120HV/VBar
TRex 500 ESP/FBL CC Ice100, MiniVBar
TRex 600LE/ OS50/ Full Size VBar/ Arizona Regulator , FrankenBlade 400/Sonic head and tail/CF Frame, Blade MSR, Bunch o' planks.. DX7/Futaba 9C
Geardaddy is offline        Reply With Quote
Old 01-27-2013, 09:54 AM   #3
Noskipallwd
Thanks for the reply CD! Well I guessed right on the orientation, and the holder going over the bearing makes sense. The instructions/parts diagram is so damn vague on a few points. CA doesn't make a very good bearing lubricant does it? I learned all about handling CA from building planks when I was younger, still screw it up once in a while though. Thanks again.
Cheers,
Shawn
Old 01-27-2013, 11:40 AM   #4
Geardaddy
No worries! Glad you got it straight.. My first bearing that I glued to my 500 TT was a mess.. thought that I'd used a minimal amount.. wrong.. Wound up having to use a deep socket to break the bearing free from the torque tube, and start over... PITA.. Don't know if you read this or not.. but when you put the actual torque tube into your tail hub.. push it all the way in, then pull it back out about 1/8th of an inch.. then put the tail parts on.. Having the tube bottomed out inside of the tail case can cause vibes down the road.. I think that was a Finless Bob trick.. but I could be mistaken..
GD
