Old 01-27-2013, 10:42 PM   #1
Mercuriell
Default Some gotchas on Kosmik
1) Need to set reverse channel on throttle for Futaba radios
2) Polarity signs hidden for battery
3) Master/Slave chamfers upside down
4) Progdisc male lead does NOT go into Kosmik, female does!
5) Trying to update non-modded early Kosmiks bricks the ESC
John
Mercuriell is offline        Reply With Quote
Old 01-27-2013, 10:42 PM   #2
Mercuriell
Default Some Kosmik and Logview Setup videos
Have spent quite a bit of time figuring out Kosmik and Logview so thought I'd put together a few vids on their usage. Logview can be downloaded here and various .ini files and Stephan's brilliant .ini generator can be found here.
Video1 - How to setup Logview to use the Kosmik - mp4 97MB
Video2 - Importing data into Logview - mp4 125MB
Link to .ini generator
Link to Logview download
It is essential to put the .ini file in the right directory - contrary to expectation this is not in program data (C:\Program Files (x86)\LogView V2\OpenFormat) but in the users folder as in this example: C:\Users\YOURUSERNAME\AppData\Roaming\LogView\Gera ete\Openformat
THEN YOU NEED TO IMPORT THE .DAT FILE - NOT OPEN IT !
You can open a .LOV file and this will have device configuration already saved in it
Please note there are TWO ways to generate .INI files - one for 3./02 and above Kosmik firmware and one for 3.01 and below - it WON'T work with the wrong version!
John
Old 01-28-2013, 01:45 AM   #3
rebeltrousers
Thanks heaps! Now I can use the logging of the Kosmik!
Silverline V-bar, Vbar Control
#205
rebeltrousers is offline        Reply With Quote
Old 01-28-2013, 02:12 AM   #4
malc1
Thanks John but for some reason can't get the 'Streamvideo' link to do anything.
---- Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N DFC OS105HZR Spirit FBL ----- MinAir Furion6 CGY750 KDE600XF G3 ------- RJX Vector 700 Pyro750-56 Comp Kosmik 200 -----T Rex 600N DFC YS60 Vbar v5.3 ----- MinAir Spectra `G` ---
malc1 is offline        Reply With Quote
Old 01-28-2013, 02:14 AM   #5
Mercuriell
Left click onto the link, then when the video page comes up right click on the download and save or left click on the stream link
John
Old 01-28-2013, 02:19 AM   #6
malc1
Yeah the usual thing but for some strange reason left clicking on stream or download file doesn't do anything and right clicking doesn't give me an option to save the file only the link to it.
Bit weird that.
Edit - I can get other Helifreak videos to work OK.
Old 01-28-2013, 03:27 AM   #7
Mercuriell
Bit weird that.
The links are OK - just checked them with another computer - must be something your end !
Anyway here are the Youtube links
John
Old 01-28-2013, 06:07 AM   #8
malc1
Ok John thanks for checking.
They work on my works PC as well. I'll check it out later on if I get 5mins.
Old 01-28-2013, 10:15 AM   #9
mtymyk
Thanks Mercuriell, great of you to take the time, this will be of great help to me .
Sent from my iPhone 4S using Tapatalk
Team Rotorquest/ SAB Heli Canada
mtymyk is offline        Reply With Quote
Old 01-28-2013, 04:39 PM   #10
Johnda
Whilst the videos are great, I still cann't get it to work.
Ive followed them exactly, however when I've created the in. file in the opend folder I go to choose a device and port, there is no open folder listed, but there is the kosmik int. file selecting tht does nothing.
Johnda is offline        Reply With Quote
Old 01-28-2013, 05:58 PM   #11
Mercuriell
What version of windows are you using and what directory are you putting in the .ini file ? You need to put the .ini file in \appdata\logview\geraete\openformat directory and then you will find it in device select list at the bottom of the list.
John
Old 01-29-2013, 03:14 AM   #12
Johnda
Thanks for the reply John, I think I'm going wrong is the 'appdata' just can't seem to find it even with search, I shall have another go this evening
Old 01-29-2013, 03:23 AM   #13
jamin_00
If you need to Johnda, I'll send you my phone number so we can talk it through. Im using Windows 7 and it was as John described above.
The difference between knowing your s**t and knowing you're s**t!
Optipower - Kontronik Drives
jamin_00 is offline        Reply With Quote
Old 01-29-2013, 05:24 AM   #14
Johnda
Thanks Ben, I'll have another play around with it this evening and see if I can sort it
Old 03-08-2013, 07:44 AM   #15
PHANTMXR6
Smile
Thanks again John.
I managed to get Logview installed and working and my ini fil eis all good as well.
I even managed to get the Kosmik jpg sorted as well.
Awesome piece of software as well. Thanks to the blokes who developed it and made it available to the masses.
Trex family.....100, 450L, 550E 3GX. Goblin 770.Goblin 700 speed machine. Goblin 380.
JR X9503.
PHANTMXR6 is offline        Reply With Quote
Old 03-18-2013, 02:25 AM   #16
rebeltrousers
What do I type in the generator for:
Pinion
Main gear
The goblin 700 has a weird system of gears and pulleys.....so is it different??
Cheers
#205
Old 03-18-2013, 11:31 PM   #17
jhheli
The Goblin 700 main gear you type in 204, and for the pinion you type the teeth on the motor pulley.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote
Old 03-19-2013, 02:27 AM   #18
rebeltrousers
Awesome thanks!! SOOOO much info to look at now!
Funny that my headspeed is about 100rpm below where the calculator said it'd be.
Could that be down to the motor KV being lower than advertised??
#205
Old 03-19-2013, 10:51 AM   #19
jhheli
No problem and yes, sometimes the motor kv is not pin point, but also the packs you use in mode 4 make a difference also and can effect headspeed....No problem.
Sponsored by :
Old 03-21-2013, 02:19 PM   #20
RyanW
Thanks John!!!
RyanW is offline        Reply With Quote
