Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 02-03-2013, 09:35 PM   #1
aviator493
Default Os 37 Hatori Pipe, which one?
Not sure which one to buy??? There are two listed for the OS37. SB-6RS or SB-7 3D.
aviator493 is offline        Reply With Quote
Old 02-03-2013, 09:58 PM   #2
tauscnc
Here is my complete setup including updates.
Hatori SAB-6RS-3D Bobby Watts Special
OS37 - OS #8 plug
Spektrum AR7200BX
Align 510 x3 cyclic
Align 520 tail
Futaba S9650 throttle
Edge Mains and align tail blades white
Coolpower 30/30
1300 2S pack - XT-60 connector
Flightpower 5 amp bec, fail safe switch
PushGlow
Align RCE-G600 Gov with magnets and its sensor
Header tank w/ align 3way filter
Fuel magnet
Homemade steel pitch slider bushing
tauseef
www.cuttingedgecnc.com
tauscnc is offline        Reply With Quote
Old 02-03-2013, 10:14 PM   #3
aviator493
Gotcha. I'll grab the same pipe! You happen to know if either will work in case the one is out of stock?
Old 02-03-2013, 10:32 PM   #4
aviator493
Nevermind, it's I stock from the link you sent me. Thanks bud!
Old 02-04-2013, 10:12 AM   #5
mamartin
If you listen to Bobby Watts on his NX4 video he talks about the pipes a little. According to Bobby he said that there both putting out about the same power just the Gaui pipe sounds a little more raspy like a 2 stroke dirt bike while the Hatori is more of a smooth sound.
From watching both fly it looks like neither is lacking in power
Mike Martin, MSH BRAIN USA Team Manager
MSH USA FLIGHT TEAM,
CYCLONE BLADES, XNOVA MOTORS,
JETI USA
www.MSHUSA.com, www.MSheli.com
mamartin is offline        Reply With Quote
Old 02-04-2013, 11:14 AM   #6
aviator493
Default Re: Os 37 Hatori Pipe, which one?
Yeah, I saw the video and definitely wanted to stick with Hatori like all my other nitros. There were two OS37 Hatori pipes and seems like the consensus is to get the Bobby Watts edition. Someone listed the part number in post above mine.
Sent from my DROID RAZR using Tapatalk 2
Old 02-04-2013, 11:15 AM   #7
aviator493
Sab-6RS-3D is one I'm going with.
