Go Back   HeliFreak > R/C Simulators Support > RealFlight Flight Sim
RealFlight Flight Sim All versions of RealFlight Sim
Old 07-07-2008, 02:02 PM   #81
divepilot
Default trex450SEV2 on a G3.5?
I have a Realflight G3.5. I am looking at a 450SEV2. Is there any way to install this heli on my sim? If so how difficult is this?
divepilot is offline        Reply With Quote
Old 07-07-2008, 03:38 PM   #82
phrank
Download and save the file to a location you can find later.
http://www.knifeedge.com/forums/down...o=file&id=3417
Use Realflight's "Import" function from the simulation menu.
After succesful import it will be available under aircraft selection.
phrank is offline        Reply With Quote
Old 08-10-2008, 03:55 AM   #83
corona007
Default G 3.5 screenshots
Goofing around.
Name:	RealFlight 2008-08-10 00-34-10-26.jpg
ID:	58460   Click image for larger version
Name:	RealFlight 2008-08-10 00-39-49-68.jpg
ID:	58461   Click image for larger version
Name:	RealFlight 2008-08-10 00-46-07-45.jpg
ID:	58462   Click image for larger version
Name:	RealFlight 2008-08-10 01-00-56-17.jpg
corona007 is offline        Reply With Quote
Old 09-27-2008, 01:59 PM   #84
divepilot
I have lost the Trex 450 SE V2 from the sim. When I try to reinstall it from my documents it tells me it's already in but when I try to put it in it tells me I don't have that heli. It seems I lost it from my list. It's been working for several months with no problem. If you can explain why I would be very thankful.
Old 10-23-2008, 07:21 PM   #85
sac - man
Default no blades ???
I installed one of the trex 450,s and it says unable to locate rotor blades 325 ????
were do I find these blades ???
sac - man is offline        Reply With Quote
Old 11-03-2008, 05:38 PM   #86
socalmedic
when I installed the link provided by phrank the heli bounces around and wont take off how do i fix this?
socalmedic is offline        Reply With Quote
Old 11-03-2008, 06:09 PM   #87
phrank
This is a side-effect of using G4.5. (I'm assuming you have upgraded to G4.5 and are now experiencing this?)
Temporary workaround here:
http://www.knifeedge.com/forums/showthread.php?t=21809
Old 11-04-2008, 01:09 AM   #88
socalmedic
Thank you phrank
Old 11-05-2008, 07:21 PM   #89
socalmedic
still having a problem it stoped bouncing on the ground but now the tail of the heli swings back and fourth? how do i fix that?
Old 11-05-2008, 08:30 PM   #90
phrank
Complete fix coming soon, the guys are doing some final tweaks on the G4.5 version.
If you can't wait, Post#7 on that same link I gave above has someone else's tweak that solved the problem for them.
Old 11-07-2008, 02:32 PM   #91
Heli1R
Credit to trexflyer02, based on what he said to do for the TRex500, I found indeed the value of Skid stiffness of 2% stopped the bouncing.
The tail wag issue goes away by reducing the gyro gain setting to 40. Until the official tweaked version for 4.5 is released the model flies well with these settings in the interim. Hope this helps.
Heli1R is offline        Reply With Quote
Old 11-07-2008, 03:40 PM   #92
phrank
Thanks Heli1R, that's a great suggestion.
Release of the 4.5 version of the Trex is almost here with some minor visual tweaks to take advantage of G4.5's new rendering. Stay Tuned.
Frank....
Old 11-27-2008, 11:20 AM   #93
ChrisH
ATTENTION ALL G4.5 USERS!
The new CDT Trex 450SE V2 for G4.5 is available for download. Please click HERE to go to the download page, and make sure to download your favorite colorscheme too!
Edge Rotorblades
Thor/Voltz Batteries
450 Pro V-Bar
130X
ChrisH is offline        Reply With Quote
Old 11-30-2008, 06:42 AM   #94
satchy
THANKS TREXFLYER YIPPIE
"So What is 3D Flying"
Definition: 3D as applied to current rc helicopter flying is any maneuver that to be performed requires the constant harmonized input of three or more controls simultaneously while the maneuver is taking place.
satchy is online now        Reply With Quote
Old 11-30-2008, 10:47 PM   #95
ChrisH
Not just me, this was a team effort over a number of months. Thank CDT
Edge Rotorblades
450 Pro V-Bar
130X
Old 12-18-2008, 04:59 AM   #96
satchy
THANKS CDT and TEAM
Old 01-17-2009, 10:38 AM   #97
panhead182
Does it matter if your real flight system has been previously registed by another owner? I cant find the Sim menu
panhead182 is offline        Reply With Quote
Old 01-01-2010, 01:33 AM   #98
rrg
Thanks Guys
rrg is offline        Reply With Quote
Old 01-01-2010, 02:16 AM   #99
ChrisH
Edge Rotorblades
450 Pro V-Bar
130X
