| RealFlight Flight Sim All versions of RealFlight Sim |
#21 |
When you first turn on G4, look at the first screen. You will see a tab that says "additional options". Click on that and register and you will get a update that will correct it.
Download and install the available update. Turn off G4 and restart. Now import the models again. Note: When importing, be sure to use the third option for gtx files. Also you will only be able to import files from G3 and G3.5. Earlier versions will not work with G4. Will work now. |
#22 |
This is a GREAT model for RF.... It has improved my muscle memory for the TREX a bunch....
But I am getting a slight list with these variants. at a hover, the rotor is about 3 degrees starboard low. The only adjustment I have made is the flybar weight. Anybody have ideas?
T-Rex 450 V2 T-Rex 250 Super Combo T-Rex 250 Custom Retired list: Gaui200 BladeCX2 |
#23 | |
Edge Rotorblades Thor/Voltz Batteries 450 Pro V-Bar 130X |
#24 |
Got it... read it... thanks a bunch
#25 |
No problem. Have fun with the model!
#26 |
Thank you for putting out a great model. I really love it
#27 |
This model is great. It is the only one I am using, as it is the closest thing to my RCT-450 I could find.
Velocity 50 FBL w/Beastx, T-rex 500ESP, 450 size scale UH-1N, T-Rex 450, mCPX BL, mCPX, Traxxas QR-1 micro quad, JR X9303, Realflight G3.5, AMA# 923167, Vice Prez Farragut Flyers |
#28 |
Hello All,
I have been trying to download this model all evening. Any chance there is someone out there willing to email the EA to me? thanks. Disregaurd. I got the file from Bryce. no time to surf the web. MUST FLY SIM! Last edited by AbdnAllHope; 12-14-2007 at 07:45 PM.. |
#29 |
Hi all I just bought the G4 and uploaded it to my Desktop. I have registed and checked for any updates.
problem is I cant seem to upload this Great Trex everyone is talking about. Kind of a let down cause I have the real thing behind me but have only hovered it twice. I have gone to "Import" and then selected the "g3x" file and a line comes up on the bottom of the sim screen that says it cant upload it because this AC does not exist in its files. I have uploaded the files from cutting edge to MY Documents. Why isnt this working Please help and thanks Trevor |
#30 | |
#31 |
Thanks for that. But I figured it out. It seems that once youve uploaded it to the G4 list of AC. It puts the Trex into a folder of its own at the top of the list. I dosnt appear as Trex with all the other AC you have to open this folder.
And Now that ive been able to use it. WOW!! it really is impressive. Good job. Hope this helps other G4 owners |
#32 | |
#33 |
I seem to be the only one with this issue, but when I import and open this Trex, the main blades, tail blads, and flybar are all off (I think they are the 600 size...). I changed the measurements in the edit menu, but I still couldn't get the heli to take off. Anyone else having this problem? Thanks.
If duct tape isn't the answer, then you must be asking the wrong question... |
#34 |
Sorry to hear you are having problems installing this model.
Could you please explain in detail how you imported the model? Which version of Realflight do you have? |
#35 |
I downloaded it from the knifeedge website and simply followed the usual import procedures: I opened realflight, went to import, selected KEX, found the file and imported it. It then says on screen that the import was successful, but when I open the model everything I previously described is off. I have RealFlight G4. I have been having problems connecting to the web on my other computer (the windows one), so maybe I need to figure that problem out and then update G4 in order for the model to work properly?
#36 |
Use the Realflight Archive option to import.
#37 | |
#38 |
I have G3 and the two 450 downloads on first page. How come one of the models breaks at tailboom right away and other model you have to hit full throttle before it also in some way self distructs?
Thanks |
#39 |
Thanks for your replies guys! I tried importing using the archive method (the import G3X method) but when I do, G4 won't recognize anything in the 450 folder as import-able. It only sees the KEX file when I try it that way, but then it imports all messed up. Has anyone else used this heli in G4 that could maybe let me know how I should properly do this?
#40 | |
