Old 11-03-2007, 06:16 AM   #1
tungym
Default Align New 3D swashplate & washout control
Without careful inspection, I find the new version is just ~10g lighter. Someone may not be interested in the weight reduction. I found the new washout has almost zero slop (though it is aluminium but not copper, hence theroretically a faster wear). The new washout arm must be used with the new swashplate. Why?
The secret is that the new swashplate has the inner swash 1mm thicker and the central ball is protruding 1mm higher. I finally find out the new design makes the central ball in the same axis as the 4 swash balls. This is very important as the old version swashplate central ball has eccentric axis with the 4 swash balls. the washout arm (the plastic arm) will wobble as the swashplate tilt (as they are not in the same axis). The wobble will cause the washout impringe on the main shaft and cause binding on pitch input.
The downside of the new swashplate is that it is 1mm thicker and on high pitch setting it may hit the central hub guiding pin. I have to shorten the pin 1mm to accomodate +/-14.5 deg pitch.
tungym is offline        Reply With Quote
Old 11-03-2007, 10:39 AM   #2
Jason Bell
The stock swashplates hit the pins as it is already :wink:
Nice write up on the upgrade:wink:
Avant RC Factory Pilot / A Main Hobbies Customer Service. Representing: Team Avant,A Main Hobbies, YS Engines, Edge Blades, Thunder Power RC, Scorpion Power Systems, Spektrum RC, Aerospire RC, Insane Canopy, Castle Creations
Jason Bell is offline        Reply With Quote
Old 11-03-2007, 10:58 AM   #3
wren1702
I installed the same setup on one of our 600Es and had to shorten the pins as well.
Alan Haney
T-Rex 600E in 500E Hughes
Swift 16 Flybarless in Approach Cobra
Outrage 550..........Outrage G5........Phazor 600
In memory of: James Archer
wren1702 is offline        Reply With Quote
Old 11-04-2007, 01:26 AM   #4
Mike3DPro
I asked about it when I was at assurance the other day and the guy said they were HOT anodized, so that they won't wear as fast, said it makes them wear at about same rate as steel. IDK about that though, in my experience, anodizing comes off rather easily.
T-rex 700E V-BAR V2-B Tail, DFC Head system, Outrage 9188 tail, 610's, Quantum 4530-500, slant gear. Scorpion Commander V 130A with SBEC, Running V-Bar gov - the best governor combo ever. Maiden Flight: 6/5/2010 - Still on stock frame & blades in 2012.
Mike3DPro is offline        Reply With Quote
Old 11-04-2007, 01:35 AM   #5
cbdane
Are you sure he didn't say "hard" anodized? Hard anodized coatings give aluminum a characteristic gray to greenish brown color (depending on the specific aluminum alloy) and it is an extremely hard and durable surface treatment. It is different from standard anodizing in which the color is given by organic dyes entrained in the oxide coating. The ball in my new swash looks hard anodized to me.
Have laser, will travel.
cbdane is online now        Reply With Quote
Old 11-04-2007, 12:39 PM   #6
Mike3DPro
Well, actually I think he said hot but he may have meant to say hard. I was thinking what is heat going to do to help at the time. I do hear things wrong from time to time - so IDK.
Nevertheless - He said it is supposed to wear more slowly than a "untreated" aluminum ball. Cuz I said right then and there as soon as he said it was aluminum - "Doesn't aluminum wear quicker?" Then he explained it to me.
Bottom line - Align should put a small description about how a "NEW" part is different than an old - all they put is NEW!
Old 11-04-2007, 05:13 PM   #7
Pinecone
It does sound like hard anodizing, versus the soft color anodizing used to, well, make stuff in various colors
Hard anodizing is used to reduce wear.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 11-04-2007, 07:26 PM   #8
Filby
So I heard that this new swash fixes some phasing issues on the 600N. Can anyone comment on this?
Filby is offline        Reply With Quote
Old 11-05-2007, 04:51 PM   #9
erniefritz
there were no phasing issues with the old swash...
erniefritz is offline        Reply With Quote
Old 11-05-2007, 04:53 PM   #10
Filby
I believe that I have phasing issues on the old swash. The heli noses up in a roll and from all the reading i have done this is highly characteristic of phasing problem.
Old 11-05-2007, 10:49 PM   #11
TMoore
http://www.fortwayneanodizing.com/01.../hard_coat.htm
http://www.fortwayneanodizing.com/01.../anodizing.htm
If the Swashplate was made of the right alloy, anodizing wouldn't be a huge factor.
TM
TMoore is offline        Reply With Quote
Old 11-06-2007, 06:13 AM   #12
Y@nkee
How can a swash make any changes to the phasing?
If there are some phase correcting on this set, wouldnt that be in the washoutbase?
Dont got a 600n yet, but i do got one on its way from Rchover ,and i did order this set with it.
So when i get it, i can tell if there are anything done to the phasing with this upgrade.
Cant wait for this thing to get here
Jan
JR DSX9, Copterx/align 450 Pro miniVbar, Tianzi TZ 50 (Stinger 50), T-Rex 600N pro Vbar, Kasama Srimok 90n ECO Vbar
Y@nkee is offline        Reply With Quote
