Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Gas
MA Gas Miniature Aircraft Gas Helicopter Support Forum
Old 02-20-2013, 01:43 PM   #1
yowser
Default Gasser conversion xcell 60?
Many of the parts for the MA line are interchangeable I think. Is it possible to convert a xcell 60 into a gasser with a zenoah? Not sold on the os 15 yet.
Logo 500 mini vbar
yowser is offline        Reply With Quote
Old 02-20-2013, 11:40 PM   #2
rbort
Default Yes, possible
You'll need new lower frames, rails on the bottom to hold the gas engine. Also you'll need a gasser clutch and fan and shroud. You can use the top 1/2 of the frames and the tail and the servo tray from the 60.
-=>Raja.
Raptor 90, Hanson 300, 267 flights
MA 1005, Hanson 280, 4060 flights, Spectra-g, Hanson 270, 3140 flights
Whiplash-g V1, Hanson 270, 1328 flights, Whiplash-g V2, Hanson 300, 45 flights
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is offline        Reply With Quote
Old 02-21-2013, 06:13 AM   #3
yowser
I am guessing the 1005 parts Raja? I will need a different pinion also or do I just buy the clutch bell with pinion and block?
I know you have some 1005 parts, any that I would need?
Logo 500 mini vbar
Old 02-21-2013, 11:19 AM   #4
rbort
Default Yes I do have alot of stuff
If you want PM me your number and I'll call you tonight and I can look through what I have.
-=>Raja.
Old 03-20-2013, 12:25 PM   #5
rcnut
Hey Raja...I have an X-Cell 60 SE... Could I convert that into a gasser? Possibly using the O.S. 15 gas motor? It might be a better fit for a 60 size heli...
Just a thought...
Team Miniature Aircraft
"I love the smell of Nitro/Gas in the morning!"
Citizen 654
rcnut is offline        Reply With Quote
Old 03-20-2013, 09:50 PM   #6
rbort
Default Yes
I used to convert 99SE kits into gassers for MIT but you'll need alot of parts and $$$s to do it. I mean you'll need an engine, muffler, clutch system, fan, shroud, lower frames, stronger upper frames if they were too thin (nitro ones) and some spacers and such.
Its certainly possible if you want to do it, and the 99se was the bling of the bling machine so making it into a gasser at the time yielded a gasser upgraded to the max.
-=>Raja.
Old 03-26-2013, 10:03 PM   #7
geomecc
rc nut. i sent u a pm
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Skookum support pilot
geomecc is offline        Reply With Quote
