Go Back   HeliFreak > Multi Rotor Support > DJI Multirotor Support
DJI Multirotor Support DJI Multirotor Support
Old 02-22-2013, 05:47 AM   #1
DJI Innovations
Default DJI Naza-M Assistant Software Error Code List
Here is the Naza-M Assistant Software Error Code List. Please read so that you can have a better understanding of the errors and how to fix it!
CFG-ERR
Configuration error, this may be caused by firmware upgrade from the old version, or abnormal Tx calibration. Re-calibrate your transmitter, power cycle your controller, and check all of the parameters.
VOL-LOW [4]
Voltage low
SN-ERR
Your S/N is not available, Please contact your dealer (Place of purchase)
VOL-LOW[6]
Voltage low
IMU-ERR
IMU ERROR,Please contact dealer. (Place of purchase)
X1-ERR
You’ve chose parameters tuning by X1/X2 channel with Tx Knob, but no signal detected on X1/X2 input channel, or Tx didn’t powered on.
X2-ERR
PMU-ERR
Please check the connection among battery, MC and PMU.
RX-ERR
Please make sure you are on the RC page of the NAZA Assistant Software, select the right receiver type or check the receiver connection, after that power cycle your controller to take effect.
COMPASS-ERR
Compass data is abnormal, please restart your Controller, if you still get this error, please contact your dealer (Place of purchase)
ERROR [25]
IMU initialization failure, may be caused by crash. Please contact dealer (Place of purchase)
ERROR [26]
Please perform Advanced Calibration.
ERROR [27]
GPS not calibrated, or magnetic field interference. Please calibrate GPS again in good condition.
Please contact your dealer for all technical support questions
We hope this answers your questions
DJI Innovations is offline        Reply With Quote
