Old 11-08-2007, 08:24 PM   #1
khaled_abobakr
Default Heat Sink for the CC Phoeninx 35 .. ???
All I can see is that metal plate inside the ESC ,, well I'm not sure if that acts as a heat sink or not ,, but if I'm using a separate BEC like the SportBec .. do I really have to install a heat sink on the ESC or not if I'm after long safe duration and cool running motor / ESC
If yes ... on which side should I install the heat sink
Thanks a lot for ur help
khaled_abobakr is offline        Reply With Quote
Old 11-08-2007, 08:31 PM   #2
swannking
I wouldn't worry about it. My CC45 running with the medusa 28-40-3400 motor barely gets warm while the motor is hot like hell. I am using a UBEC on a 4S A123 system though. But if the ESC doesn't feel hot, don't bother.
swannking is offline        Reply With Quote
Old 11-08-2007, 09:37 PM   #3
khaled_abobakr
Thanks a lot for the info
Old 11-09-2007, 05:41 AM   #4
chadjay
I have the CC35 as well, and without a separate BEC it will get hot. If you are trying to setup the head with lipo plugged in and using the CC35 bec its gets quite hot. I have just installed a Sportbec and also changed out my head linkages, so during head setup I would check the heat. No problems with Sportbec installed! CC35 was cool and Sportbec wasn't even warm. I did notice a slight change in servo speed with 6V. The cyclic servos seemed a bit faster!
<<450SE V2, CC35, Kong Power 3S 25C 2200, 430XL, 401 w/9650, HS65MG, tail weight mod>>
<<Blade MCX with glow-in-the-dark setup, carbon fiber canopy>>
<<Yellow 600SNP, 8717s, 770 & 8900G, AR7100, Multigov Pro, Align 2 in 1(used for glow driver only)>>
chadjay is offline        Reply With Quote
Old 11-09-2007, 08:58 AM   #5
HeliSmith
This is the reason I went with a BEC too. My ESC never gets warm.
I did fry my son's Phoenix 10 ESC on his heli. Good thing for that flat rate repair program they have. I love CC
(Compass Warp 360 w/Stock Motor (17t) running from a YGE60 governed at 3200RPM by the Vbar Black, sporting MKS DS95 on cyclic and JR3500G on tail)
Proud Field Representative for the following
HeliSmith is offline        Reply With Quote
Old 11-09-2007, 06:25 PM   #6
carlo_the_wonder_frog
I love the flat rate program as well. Both times they just sent me a brand new ESC in replacement for my used and abused 3 yr old Phx 10 and 3 year old Mamba 35, it only cost $15 for each, best in the business IMO.
carlo_the_wonder_frog is offline        Reply With Quote
