Go Back   HeliFreak > R/C Helicopter Support > Multi Rotor Helicopters
Multi Rotor Helicopters Multi Rotor Helicopters Info and Support - Tandem, Quadcopters, Tricopters, Octocopters, and Hexacopters
Old 11-15-2007, 05:56 AM   #1
Reidar7
Default 2Rexx HeliCam Project
I am working on a project; aiming to get a stable, heavy duty, smooth; air-platform for video/film/photo.
After working on a tri- and quadra-chopper model on the drawing-desk, I have (most probably) landed on a tandem-rotor solution. This mainly due to the electronics involved in the syncro of 3 and 4 rotors. (I do know that Draganfly has a working model, but this is to my knowledge for leightweight equipment).
So I am asking for advices, experience transfer and creative suggestions.
The current setup, is for a Canon XL-H1 (HDV/HD-Cam) w/std. lens. Adding the required FPV-equipment, including OSD w/GPS and sensors; I do believe I am up to a required lifting-capasity of 6-8 kgs.
So I am thinking of a twin-rex, with extended frame;
+ incerasing the number of blades with: Precison AH V 1.0 5 Bladed Rotor Head Assembly.
And then; what type of engine to use.
Jet would be nice, but limitations related to noice, exhaust etc. is reducing my field of work. (Maybe I am ending up with 2 models..).. so an electric solution would be nice (if possible).
Anyone with experience on this area, and/or who knows about lifting capacity of the TwinRexx, with the current configuration?
Very best regards
Reidar Huseby
Reidar7 is offline        Reply With Quote
Old 11-15-2007, 06:45 AM   #2
DebianDog
The weight of that camera (fully loaded) 8.3 lbs. (3750g) plus all your other gear. You are going to need a LOT more helicopter. Trex is out of the question even with 2 rotors
Do you already know how to fly?
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 11-15-2007, 08:36 AM   #3
Reidar7
About flying; I will give the same reply as when I was asked if I knew photo/film. "There is a lot more to learn than I now know. Hence, I do know a lot of what I need to know; that is giving me the direction - the rest; the rest is speed and preciscion." ;-)
I love helicopters. I love photo and film. So the combination has to be great
Now for the chopper part.
My experience is limited to small electric models; and that is why I need more experience/input when deciding what to choose. I still believe that a tandem could be a solution; but I am not certain about the configuration.
In my so far short life, I have understood that asking qualified people; and getting qualified info in return normally gives a short line to the goal. So my next question is then; do you know any data/figures? Then the next step would be to figure out the distance between the existing models/solutions, and to the desired solution/model.
Any suggestion for other solutions is also welcome.
Thanks in advance.
Reidar
Old 11-15-2007, 09:15 AM   #4
DebianDog
I am a photo/video "wantta be" myself and got in to helicopters because I wanted to do AP work. When I finally maidened my AP ship $2000 + $1500 in gear + a $2500 HD camera I was too nervous to do any good work. So I decided that I would concentrate on being a better pilot for a few years and keep the majority of my camera work on the ground.
I am using a Panasonic HVX200P now and my current rig will not even hold the camera so I will have some work to do in the future to get that baby flying. I am waiting to see what Bergen does with the Observer as I know they are doing testing now with a LARGE electric bird.
Bergen does make several "turn key" solutions now and customer support is GREAT!
http://www.bergenrc.com/
another company to watch is http://www.airscooter.net
Old 11-16-2007, 04:55 AM   #5
Reidar7
Thanks.
The airscooter seems to be an adequate option. The stability given by the use of counter-rotors might be a workable solution for this project.
And also Bergen/Observer with a big electric bird seems interesting enough to await the result prior to deciding on the build-project.
Control of the model?
After several years off marriage, I have come to learn that control is an illusion. A pleasent illusion, but still - an illusion. ;-)
So my approach to control, is to be absolutely aware of what I can do - and what I (for the time beeing) can not do. And then to train/learn on what I need to know better, following the KTT-C model. (Knowledge (the basic core-knowledge) - Technique (the fundamental basics) -Training (focus on direction and presicion) - Control (as a result of the previous chain).
You have given me a good input on what is the most important aspect(s); and one of them is to learn to control the model better. I will await the models beeing develop, and keep on training with both a Lama (for the airscooter) and a 3D-model (for the Observer) - in order to be ready for both options.
Thank you for informative feedback.
Reidar
Old 11-16-2007, 06:27 AM   #6
kgfly
Reidar, search around on the AP forum here, there is a good thread about setting up a MaxiJoker2 as an electric cameraship....
..here, take a look at these threads, I think you will find them interesting:
http://www.helifreak.com/showthread.php?t=41518
http://www.helifreak.com/showthread.php?t=40203
I suspect that twin-rotor heli will be less reliable than a conventional single-rotor airframe and harder to setup and harder to get to a low vibration configuration which I understand to be is vital for good video.
With 12s2p 4600mAh A123 packs (under $250 each) and the right charging solution (eg Mastech CCCV 50V/20A power-supply) you should be able to get something around 10min flights and 20min charging. If you need extended flight time in the field, with 3 packs, 2 chargers and a generator you could fly non-stop.
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is online now        Reply With Quote
