Go Back   HeliFreak > Multi Rotor Support > Flight Controllers (NAZA, Wookong, A2, etc...) > DJI Multirotor Forum(A2/WKM)
DJI Multirotor Forum(A2/WKM) DJI Multirotor Forum(A2/WKM)
Old 03-26-2013, 04:05 PM   #1
Pig1835
Default Naza gain settings for dummies
I survived my first flight in F450 with default settings. I want to tune to my likings, but I don't even know what to look for. Can someone explain what a particular change in gain will do to flight characteristcs ?
Pig1835 is offline        Reply With Quote
Old 03-26-2013, 05:42 PM   #2
P.I.Engineer
higher gain, more locked in feeling, gain too high, it will oscillate/shake.
gain too low, it will feel mushy.
just gotta tweak till you find what you like
Protos 380
TX: Fr-Sky Taranis
P.I.Engineer is offline        Reply With Quote
Old 03-27-2013, 07:05 PM   #3
Pig1835
I flew 2 more battery packs today. I had all the settings as recommended in the Naza manual for the F450
pitch 150
roll 150
yaw 100
vertical 105
attitude pitch 150
attitude roll 150
I set up the flaps switch on my Dx6i to change all the settings to 20% higher values
Flying in Manual mode I don't think I saw a difference in the recommended settings to the +20% Should I try going higher on all settings until I see a problem, then back down a bit?
If I switched over to Attitude mode, I did have some oscillation. I was most noticeable when descending straight down. Should I try lowering the attitude gain values for my next flight? How much? 10, 15, 20% ?
Old 03-29-2013, 06:18 AM   #4
02deuce
Usually the oscillation when descending straight down is caused by dirty air and is common. In most cases the stock (DJI recommended) gains are good to go. I test my pitch and roll gains in atti mode by hovering my MR in front of me and flicking my Aileron and Elevator control sticks on the radio. By flicking I am giving sharp Aileron & Elevator stick inputs then letting the radio control sticks snap back to center position on their own. You will notice that the higher the gain the faster the MR will snap back to a level hover. To much gain it will snap back and oscillate to low it is slow and mushy return to level hover. I use 20% increments and fine adjust from their. I you want to see big differences in gain settings set the low gain to around 80 and the high gain to around 220 and you will see the very noticeable differences between to high and to low gains.
Trex 700N, 700E, 600E, 500E all Vbar 5.2 Pro FBL
Dji F550 WKM Data Link 900MHZ
DJI F450 Naza/GPS FPV 5.8 vtx
TBS Disco w Core Naza GPS FPV 1.2 vtx MT Tiger motors
02deuce is offline        Reply With Quote
Old 04-06-2013, 08:05 PM   #5
Pig1835
I think I'm done experimenting and sticking with these settings:
pitch 170
roll 170
yaw 120
vertical 120
attitude pitch 120
attitude roll 120
Old 12-20-2013, 07:52 PM   #6
Swoop
Can someone explain the difference between basic and attitude gains? Would that be the behavior when in normal versus attitude mode? and does the GPS mode behavior follow attitude gain? thanks in advance
Chris
Swoop is offline        Reply With Quote
Old 12-20-2013, 08:05 PM   #7
toys2cars2toys
Here's a good explanation
Originally Posted by Empire Support 2 View Post
The main gain is responsible for how the craft responds to the input from the environment. That means wind ext. The higher the basic gains, the quicker the craft responds to the input from the sensors. ATTI gains are how the craft responds to your stick inputs. Think of it as expo on the control channels. The lower the gains the less responsive the sticks, the higher the more responsive they are. The guys in China like their ATTI high, but they are test pilots and also not do video A/P. You choice on how you want to go.
from here
http://www.helifreak.com/showthread.php?t=584460
toys2cars2toys is offline        Reply With Quote
Old 12-20-2013, 08:50 PM   #8
Swoop
Perfect thank you T2C2T. I just looked at that thread you posted, good info. I should have done a search.
_Chris
