Go Back   HeliFreak > R/C Helicopter Support > HeliDirect
HeliDirect HeliDirect HDX300, 450, 500, 550, 600 Factory Sponsored Support Forum
Old 11-18-2007, 07:25 PM   #1
helidirect
Default HDX500 Manuals
HDX500SE manual
http://www.helidirect.com/upload/HDX...anual-V1.9.pdf
HDX500SAS (use standard servos) Manual
http://helidirect.com/upload/HDX500S..._Full_V1.1.pdf
HDX500SAH (using hitec servos) Manual
http://helidirect.com/upload/HDX500S..._Full_V1.2.pdf
Steve
www.helidirect.com
helidirect is offline        Reply With Quote
Old 12-17-2007, 04:24 PM   #2
Ticidytoc
Thanks for posting these Steve.
Matt
A Helicopter, Brushless Motor, Esc, Battery, Servos, RX
Ticidytoc is offline        Reply With Quote
Old 02-16-2008, 08:37 AM   #3
scarr
Default HDX500SE V2
Is there a manual on the HDX500SE V2 yet?
T-Rex 450SE, Gaui 200, Swift 550
scarr is offline        Reply With Quote
Old 03-01-2008, 06:22 AM   #4
tom
Default manual
Is there a manual for the HDX 500 se V2 bought one and using the wrong one when will ther be one for the V2
tom is offline        Reply With Quote
Old 03-01-2008, 06:50 AM   #5
Greg Alderman
Tom, Unfortunately there is not a manual for the V2 yet...I certainly apologize for this...this does seems a little backwards, but we wanted to address some of the issues on parts and such and the V2 manual did not get released prior to the part changes...I will be the first to say that our all of our manuals are being worked on and there will be one down the road...as soon as I get a draft copy and approve it, the V2 will be released...but until then plese feel free to PM me, email me ro call be if you get stuck on something...my info is below in my Sig...
I am building and setting up my V2 this weekend so I hopefully can answers any of questions you come up with...
Best Regards,
Greg Alderman
Manager, Prestige RC
866-441-5537 Ext 802
Greg Alderman is offline        Reply With Quote
Old 08-24-2008, 05:53 AM   #6
whitey
Default V2 Manual
Greg
Any developments here?
whitey is offline        Reply With Quote
Old 08-24-2008, 10:24 AM   #7
Wyldman
6+ months later, & we're still waiting for proper documentation. Doesn't seem to be much interest in finishing the job on this project, or are you waiting to release the V3 first?
Wyldman
AMA 862241
Wyldman is offline        Reply With Quote
Old 09-13-2008, 11:15 PM   #8
Mon_t
Well there's a new model due out shortly, so we'll see.
Mon_t is offline        Reply With Quote
Old 10-22-2010, 12:44 AM   #9
newflyguy1
Default any HC500 videos
anyting on the HC500, is there a lot of differences from the other 500 models? i have only recently received a great HC500 and never got a manual with it.
wheres some good places for info on this model?
newflyguy1 is offline        Reply With Quote
Old 10-22-2010, 07:49 AM   #10
60something
There isn't, other than what's on this site and the closely related Sonic/3DX 500. machine. The HDX HC500SE starts life as an OEM heli labeled the HC500 manufactured by a CNC company in China. Best ask your questions on this forum and we'll try to answer them for you (on the HC500 - I have no experience with the original HDX500 and 450 series).
There is an assembly manual of sorts (link) on the Helidirect order page. It gives an overview of the build and is generally ok, but things like head links are completely out of whack.
The HC500 is an outgrowth of the original HDX/3DX machines and incorporates a number of improvements, as well as the specific design upgrades via Charley Stevens and Henry Caldwell.
No setup manual was ever provided. I hope to remedy that in the coming weeks, as I finish getting my own new HC500 into flight trim. I have come across a number of build issues (small ones) which I will try to elaborate later.
The head is a "standard" "trex-style" (which itself is a "standard" Chinese-designed CCPM head), so therefore standard setup rules apply (see Finless Bob's heli setup videos, especially "10b" head setup for general set up. The head linkage layout measurments in the "guide" are not correct, nor are the ball link choices to achieve the correct alignments. At least not on the head as presently supplied. Be aware that the HC500 OEM base product is subject to continous development so that things like head configurations may change with time or parts supply chain. HD's supply will likely continue to reflect their labelled product, but there may be variation in other market supply. Cyclic servo choice also affects linkages for the lower link set, due to positional differences.
The HC500SE is a solid classy machine, but it suffers greatly from inadequate documentation.
Schluter Champion, Kavan Allouette, TRex550E-FB, HC500SE, CloneT450pro-4bladed, Blade 400, WK 4F200, Xaircraft X650, and a CB180D, usually in a tree.
60something is offline        Reply With Quote
Old 10-22-2010, 04:59 PM   #11
rpheliman
Ya...what he said.
Heli - 1 HC 500 G10, Planks - PZ P-51BL, UM P-51, PZ T-28D, UM T-28, UM THE BEAST, UM 3D BEAST, UM SBACH 342, Extra 300, HYPE MX-2, EFlite Apprentice, UM Carbon Cub SS, All Spektrum controlled!!
rpheliman is offline        Reply With Quote
Old 10-15-2012, 02:29 PM   #12
chuter1
Hi there, would you, could you ,provide set up parameters for HC500 on a DX6I?
chuter1 is offline        Reply With Quote
