| Electric Micro/Mini Helicopters Electric Micro Helicopters Discussion |
I am working on a list of common replacement parts to build what I call an O-CRAP kit for my Sky Shark. (Crash Repair and Parts) Anyhow, I did the same thing for my Heli-Max and folks liked it.
I've already got a decent listing for rotors, LiPos and tail blades. What other common parts need to be replaced in the event of a crash? (I haven't crashed yet) I plan to put together a field repair kit once I get a good idea of what will break after a decent crash. I'm not looking to rebuild my heli from scratch. Just enough parts to get it flying again while in the field. Once I get a good sized list I'll make it available to anyone that would like it. Ted
Ted Schubert I always have fun. Some times are more fun than others. I can't remember half the crap I forgot. |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Here are the field-capable repairs I've made thus far:
Main blades Tail blades Main shafts Feathering shafts Tail shafts Booms Fins Main gears Cyclic servo arms (after replacing the servos' plastic gears w/ metal gears) Flybars Struts
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
Alan,
Do you have any parts numbers for those items?? Ted
Here is a sample of what I have so far. I have not used all of these, but they very close to the original parts.
It looks a lot more organized in an excell format I promise. LiPo Packs:Brand:Specs:Dimensions:Vendor:Part #:Price:Notes:Air Thunder:2200 mAh/11.1V/25C30x37x113mmHeli-Proz441122$63.99Align2100 mAh/11.1V/22C33x23x106mmHeli-Proz385015$63.99Air Thunder:2200 mAh/11.1V/25C30x37x113mmHot HeliAT22003S1P$62.94Thunder Power2200 mAh/11.1V/25C33x25x107mmHot HeliTP2200-3SX$84.99Air Thunder:2200 mAh/11.1V/25C30x37x113mmRC-TekAT3S222$117.952-Pack= $58.97 eaAir Thunder:2200 mAh/11.1V/25C30x37x113mmHeli Hobby4S1P$64.99Thunder Power2200 mAh/11.1 V33x25x107mmHeli HobbyeXtreme V2$84.99 Main Rotor Blades:Brand:Specs:Dimensions:Vendor:Part #:Price:Notes:RC-Tek (Fiber Glass)325mmRC-Tek450-FG325B$18.95RC-Tek (Wood)325mmRC-TekWB-325W$13.95V-Blades325mmHeli-Proz129650$57.99Radix325mmHeli-Proz143315$44.99Radix325mmHeli HobbyCY-YB325$44.99Radix Cutis Youngblood325mmHobby Shop WorldYEI-YB-325$44.99MS White (Fiber Glass)325mmHeli-Proz175350$30.99MS (Carbon)325mmHeli-Proz175399$34.99Carbon Night Blades325mmHeli-Proz780020$49.99Mavrikk E Series (Carbon)325mmHeli-Proz802320$34.99Micro Heli (Carbon)Super Bright Night Blades325mmHeli HobbyCFN290$59.95Extreme Composites325mmHeli HobbyMT3000C$58.00 Tail Rotor Blades:Brand:Specs:Dimensions:Vendor:Part #:Price:Notes:K&B (Black)59.6mm (L) x 3mm (W)RC-TekKB450BK$4.95K&B (Green)59.6mm (L) x 3mm (W)RC-TekKB450GN$4.95K&B (Green)59.6mm (L) x 3mm (W)Heli-Proz102377$3.99K&B (Yellow)59.6mm (L) x 3mm (W)RC-TekKB450YL$4.95K&B (Yellow)59.6mm (L) x 3mm (W)Heli-Proz102376$3.99K&B (Orange)59.6mm (L) x 3mm (W)Heli-Proz102378$3.99Ted
Not RC-Tek numbers; I usually use the T-Rex equivalent parts due to LHS availability.
#6 |
Alan,
That's fine. I could still use them. Thanks Ted Happy Thanksgiving!
#7 |
OK, then here are my typical replacement part numbers:
Main blades: Align HS1158-01 (325 Pro woodies) Tail blades: Align HS1208 or (preferred) K&B Dream Designs 4007, 4008, or 4009 Main shafts: Align HS1011-3 Feathering shafts: Align HS1003 Tail shafts: RC-Tek 450-2026 (three per package; all have preinstalled pinions) Booms: RC-Tek 450-2054 (Diablo) or 450-2055 (Sky-Shark) Fins: RC-Tek 450-2033 (Sky-Shark) or 450-2034 (Diablo) Main gears: RC-Tek 450-2038 (two per package; both have preinstalled one-way bearings) Cyclic servo arms (after replacing the servos' plastic gears w/ metal gears): depends on your servo Flybars: Align HS1184 (220mm) Struts: Gorilla Gear, standard profile I'll also add that I replaced the stock paddles with Gorilla Pro-grammable paddles. I've also attached the RC-Tek November price list, which has all the RC-Tek part numbers.
#8 |
Alan
Thank you for the parts info. Just to give everone a heads up, I didn't buy a super computer and I didn't master CAD, but I did get the CAD program to work today. Now I have a parts breakdown, but I'm still looking for parts numbers. ![]() So the list goes on. Ted
#9 |
I think I have enough parts info gathered to put the list out there. I want to say thank you to everyone that pointed me in a direction or provided me with parts info.
I have to throw this out there though. I have not ordered or tried out most of these parts. I got these parts numbers from vendors, RC Tek and folks hooking me up with their info. I highly encourage you to first take your business to RC Tek since they have provided us with a killer helicopter, this is their product and they are the subject experts and they deserve the respect and our business. Also, if you do go with a vendor other than RC Tek, you really should call them to verify that their parts will fit properly on your heli. You should work out any issues with the vendor. I hope this helps eveyone out. Until I figure out how to convert an excell spreadsheet and attach it to this forum send me a pm or email and I'll send the list to you. Ted
#10 |
The main reason I typically use Align parts is because they're locally available, so I may only end up losing a few hours or one day instead of having to wait 2 days (3 if it's over a weekend) for parts to arrive. I will admit that RC-Tek parts such as main gears and tail shafts are really nice because they're typically a little less expensive than the equivalent Align parts and they can be installed on the bird straight out of the package instead of having to swap out one-way bearings or belt pinions.
#11 |
If anyone's looking for a pretty complete parts list for RC Tek Sky Shark and Diablo let me know. I think I'm done for now.
Ted
#12 |
Are Align tailshafts, PN HS1021-2, intercgangeable for the RC-Tek, PN 450-2280?
#13 |
Sorry for the typo...
Align tailshaft PN should have been HS1021-3. |
#14 |
As far as I know, yes. However, the RC-Tek shafts are superior IMO because they come as complete units instead of three shafts with only one pinion.
#15 |
This may sound canned, but oh well........
I would prefer to make all my purchases through RC-TEK. I am a totally pleased customer. I placed an order on 11/18, a Sunday. This purchase totalled slightly over $100.00 I had questions regarding the parts that I needed, and in the process of asking, I messed up my account. Meanwhile, a firewall blocked some automated responses. The net result was that RC-TEK answered my questions. All my questions. In retrospect, some of my questions were... well.... stupid. I received 10 emails / responses from RC-TEK on a SUnday, after 8:00 P.M. for a $100.00 order. They earned my appreciation the hard way. The tailshafts are all that would keep me from flying tomorrow. I would like to get some from a LHS, and build a stock for ongoing repairs from RC-TEK. By the way, BUM, your recomendation weighed heavily in my decision to go with RC-TEK for the DIablo. Thank you. I really like the kit, and every dealing with RC-TEK has been positive. If this seems to anyone like a cheesy plug for RC-TEK , PM me. I will copy some of the correspondance. |
#16 |
Panzer 4.
No, please don't misunderstand me. I totally agree with you. RC Tek has gone above and beyond for me as well. The purpose of this list is not to take anything away from RC Tek. I list the RC Tek part first on almost everything. If you went to the RC Tek Parts window now, there may only be a dozzen or so parts listed for the Diablo and Sky Shark. I tracked down a whole lot more. In addition to the RC Tek info I also listed Align and a few others. I highly encourage you to first take your business to RC Tek since they have provided us with a killer helicopter, this is their product and they are the subject experts and they deserve the respect and our business. I got a pm a few nights ago from RC Tek encouraging me to continue with the list. Ted
#17 | |
My biggest frustration with RC-Tek is that I can't just go to their online store and order everything I need because they've been negligent in getting the site updated with a full catalog of parts. Everything has to be done via e-mail and PM.
#18 |
Alan... SooOOoooOOOOn... all will be well and you will be able to order EVERYTHING we have online without emailing us.
This coming week - 220mm flybar rods and CF all around on the paddles and blades. Everyone - thanks for your support and taking a chance on us with your business. We remember everyday who keeps the lights on and allows us to progress. ![]() Regards, Scott |
#19 | |
I look forward to it!!
