| 3D Forum Discussions for 3D applications using CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix Digimix-3. |
Has anyone found a neat and tidy way to mount all those little black boxes? I'm struggling to find places to mount everything.
So far the best layout I've found is: Rx and Cyclock stacked next to elevator servo Tail gyro (401) underneath tail servo (hope I never need to get at the Limit pot) Roll cyclic gyro (SL720) on bulkhead next to tail servo - very close to tail gyro Pitch cyclic gyro (SL720) looks like it'll have to go behind the elevator servo on a custom bracket And the wiring, when I get it all plugged in, is going to look like an explosion in a spaghetti factory. Has anyone come up with a better solution to this 3D puzzle? |
V-Bar
Ian Watson Avant Aurora, YS91 SR, Hatori SB19, GY611, V-Blade 690 smooth extremes Logo 600 3D, V-Bar, Hacker ElectricTurbine A50-12L-8P-ET, Flightpower 10s1p 5350 EVOLITE, 600mm V Extremes |
I know, but then what would I do with all those spare gyros?
Liquidate for price of V-Stabi
#5 | |
A Helicopter, Brushless Motor, Esc, Battery, Servos, RX |
#6 |
Th Cyclock works pretty well on my 500. The aileron gyro is just behind the mainshaft fixed to the vertical surface in front of the elevator servo, it's a little tight but it's out of the way. The elevator gyro is fixed to the side of the elevator servoand the cyclock unit is behind the elevator servo, it all manages to fit inside the canopy.
Steve H Trex 600N Sport, 700N , Trex 250, Beam E4, Trex 550E, Raptor E550, Mikado Logo 500 3D, now a happy user of Futaba 10CG |
#7 |
Aha, good thinking Steve! I never thought of using that bulkhead in front of the mainshaft.
You don't get any vibration problems from mounting a gyro on the elevator servo? Thanks for the great idea, I'll go and have another shot at it. Ian |
#8 |
Not vibration problems at all, I actually got this layout from Tean who posts on Heliaddicts and Runryder. I've not tried a V Bar setup athough I've seen plenty as the whole Mikado team was using them at 3D Masters but comparing flight performance with the CSM setup I can't justify spending the extra cash just to save a bit of space
#9 |
I have to agree, the V-Bar gear may be tidy but the price is a bit too salty!
#10 |
I don't understand the price problem. In the USA a cylock and 3 sl 720's would be about $650.00 if bought in a package. Much more seperately. The vStabi electronics are $699.00. A $50 saving doesn't seem like much to me.
Doug |
#11 |
If you're starting from zero, then the difference in price isn't too much, but I already had a 401 lying around to use on the tail. In the UK a V-Bar system (without air pressure sensor) costs the equivalent of $1000. A complete CSM package with 2 SL720s costs the equivalent of $600, so the saving was around $400, not $50.
It's looking more likely that I'll give the V-Bar a try on the next build. |
#12 |
If you already have the tail gyro then of course it is cheaper. At $1000 for the vStabi without pressure sensor I sure would consider ordering from the USA. It;s funny how these things are priced for different markets. Sometimes in the past I have ordered things from England or Europe. Nowadays with the devalued US dollar it generally does not pay.
Doug |
