Old 11-24-2007, 08:18 AM   #1
wbplomp
Default Check out this battery & ESC mounting plate, simple but effective!
Hi,
I want to share something with you guys. Check out this battery & mounting plate for your T-Rex 450 that a good friend of mine CNC made for us. It is simple, but very effective. I'm very happy with it.
I friend of mine asked me if I liked to have a longer battery mounting plate CNC made. At first I did not see any advantage. But we where brainstorming about it, When you mount your ESC in front, it is somewhat unhandy to mount, not easy with the wires and it does not give enough cooling. I actually wanted to mount the ESC upside down on the battery plate, but that gave some problems with the length of the battery plate, the tyrips and hook and loop tape You also have to make sure that ESC and battery do not heat each other up. So we came up with the following idea... He made it by CNC machine and did a great job. It is made of carbon and aluminium tubes, it only ways a few grams and it works great! Cees, thanks a lot!
Boudewijn
ID:	31505   Click image for larger version
ID:	31506   Click image for larger version
Name:	Battery Mounting Plate 017.jpg
ID:	31507   Click image for larger version
Name:	Battery Mounting Plate 021.jpg
wbplomp is offline        Reply With Quote
Old 11-24-2007, 09:48 AM   #2
Finless
Team Taco VP
That looks cool!!!!!!
Now if Kevin (Fireup) would ever get his super strong metal plate bracket out (almost unbreakable) that would for sure be a great combo! That small backet breaks easily in a crash and Kevin made a new stronger one that I have yet to see him break! Trust me that's saying something!!!!
Kevin where's the brackets dude
Bob
Old 11-24-2007, 10:06 AM   #3
wbplomp
Ofcourse my buddy Cees can make it stronger, by making it thicker and/-or fill up the gaps. But you have to make sure your frame doesn't brake. But anyway, do you like the design?
Boudewijn
Old 11-24-2007, 10:11 AM   #4
TomRex
Swapped the stock plate for a BF carbon plate from day 1, easier to balance with different batterys. Flexible enough not to break in crashes so far.
TomRex is offline        Reply With Quote
Old 11-24-2007, 10:15 AM   #5
Helifarns
I think it's awesome!! Can he make more?
btw, which straps are those? Align 600?
Helifarns is offline        Reply With Quote
Old 11-24-2007, 10:18 AM   #6
wbplomp
Wink
Yeah I bet you will with 4S ;-)
No, sorry I don't think he is planning to. You can buy these straps seperatly, they are probrbaly for a 450. They come in different sizes. But I won't use these, I also have bigger ones.
Old 11-24-2007, 10:19 AM   #7
swannking
What is the advantage of having the ESC mount under the battery tray vs mounting it on the bottom plate? With a nose in crash, the ESC could be toasted either way. I dented the capacitors of the align ESC in a nose in crash when I used to mount it on the bottom plate upfront. Now I mount my CC45 on the size.
swannking is offline        Reply With Quote
Old 11-24-2007, 10:21 AM   #8
oppie
TomRex, What is that 4s battery your using?
MikadoUSA Rep
Logo 690 SX Logo 500SE Vbar,
Logo 550SX Vbar Control
oppie is offline        Reply With Quote
Old 11-24-2007, 10:24 AM   #9
Rogan
A robust battery plate would be nice. :'/
Who's going to start making them then?
The above text is not intended to cause offense, unless implicitly stated.
Rogan is offline        Reply With Quote
Old 11-24-2007, 10:24 AM   #10
wbplomp
Originally Posted by swannking View Post
What is the advantage of having the ESC mount under the battery tray vs mounting it on the bottom plate? With a nose in crash, the ESC could be toasted either way. I dented the capacitors of the align ESC in a nose in crash.
Well, first of all it is way more easier to mount this way. You don't have to push your ESC and wires so close to the motor. And your ESC cooling ribs are facing the hole in the canopy. But the overal temperature won't be that different I guess.
By the way, if you have let's say a SportBEC you can mount that one on the bottem plate. ;-)
Old 11-24-2007, 10:38 AM   #11
TomRex
wpb, How about shorten the back spacers, slide the esc plate back a fuzz tap and mount on the mounting plate for more rigidity. Just a thought...
oppie, FP 25c 1800 4s
Old 11-24-2007, 10:46 AM   #12
wbplomp
I don't get it. What are backspacers actually?
Old 11-24-2007, 10:51 AM   #13
Helifarns
I think he means these:
Old 11-24-2007, 10:56 AM   #14
wbplomp
Yeah, I got the feeling he meant that. That is one thing I am thinking about. But at the moment it sits fine to me. Maybe I will do that later. Thanks!
Old 11-24-2007, 11:54 AM   #15
dct
Sorry,but to me,it looks like it would break more easily . You are adding more weight to it by adding the esc to the battery weight.
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And
T-rex 450 Pro, DFC with AR7200BX , Blade 300CFX, and Two, Blade 130X , Blade 350QX .!
dct is offline        Reply With Quote
Old 11-24-2007, 12:03 PM   #16
Rogan
Compared to the battery? I don't think so.
Old 11-24-2007, 01:19 PM   #17
wbplomp
No problem, I understand. But ofcourse it can break easily, but not more than usual. If it breaks it will break at the battery mounting plate as with every origional battery mounting plate. If we find this to be an issue, we will make it more robust.
There is absolutly no problem with the weight, this T-Rex is perfectly in balance. As far as I can remember it is nog more than 6 grams extra total, but I can't remember for sure. Anyway, It can't be much, because it feels like nothing.
