Go Back   HeliFreak > R/C Helicopters > Aerial Videography and Photography > FPV and Real time Video
FPV and Real time Video Discussions of receiving video in realtime from the aircraft
Old 04-14-2013, 10:17 AM   #1
Rossmans
Default OSD Info from Align APS and DJI Naza
Hi everyone
I've been flying around with an Align 550 with an APS system and a quad running a DJI Naza with GPS
Both of these unit can do a return to home self levelling and hold, therefore must contain all the information an osd unit needs to display positional information
Has any one worked out the wiring on these units and developed a cable to interrogate the units for the information. I have seem some items on the web showing a unit that works with the DJI, but this involves opening up the GPS and soldering onto an internal board and I don't fancy such intricate soldering since for me this kind of soldering doesn't always work well
Rossmans is offline        Reply With Quote
Old 04-14-2013, 12:38 PM   #2
sl4ppy
Instead of hacking something, why not just get this?
http://www.dji-innovations.com/products/iosd/overview/
sl4ppy is offline        Reply With Quote
Old 04-15-2013, 06:32 AM   #3
zeeflyboy
I don't believe that works with Naza sl4ppy, only Wookong and Ace one.
to answer the OP, yes there are a few people that have done this. If you google Naza OSD you should turn up some hits... I believe there was a thread on rcgroups about one such system.
Blade mCP X - Brushless, XP-7A, HP05S
Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i
Align AH-1 Cobra (T-Rex 500)
Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188
zeeflyboy is offline        Reply With Quote
Old 04-15-2013, 07:15 AM   #4
Rossmans
I've had at look at the DJI OSD and it isn't currently capable of interfacing with the NAZA unit you’d need a WKM or similar high spec unit to make the interface work.
Maybe it's one to speak to DJI about directly and see if they are planning to launch something in the near future before attempting any home spun soldering efforts.
Old 04-15-2013, 05:43 PM   #5
sl4ppy
Ahh that sux.
I suspect its just a firmware change.. perhaps enough user demand would encourage them to make the update?
Old 04-15-2013, 05:46 PM   #6
zeeflyboy
Doubtful, they seem to like to artificially differentiate and protect their more expensive product lines.
Feel free to try however lol.
Old 04-26-2013, 10:31 AM   #7
DebianDog
In the V2 coming out soon this is addressed
NEW NAZA V2 Comming Soon. What’s new with the NAZA V2:
New Hardware - PMU V2
New case design with CANBUS port. Enhanced BEC functionality, better heat dissipation. Extra CANBUS ports, enhances the scalability of the system and will support Gopro Zenmuse, iOSD and Bluetooth module for assistant software use on smart phones in the future, etc..
Later NAZA V1 can also be upgraded using PMU V2 and s...upport Gopro Zenmuse, iOSD and Bluetooth module..
Main Controller
The hardware structure has been optimized and the scalability and performance of the flight control system has been enhanced
Independent LED Module
What’s new with the NAZA V2 : Firmware and functions
- New attitude stabilization algorithm, provides better flight performance / maneuverability;
- New flight control performance, provides better flight experience; (flight control is smoother, take-off is easier, and solved the swinging problem when descending at high speed.)
- Support for Octo-rotor;
- One-motor stopped still can land safely (Hexa-rotor, Octo-rotor)
- Automatic course deviation compensation, reduced the effects of magnetic disturbance; interference around the compass detection & warning;
- Added IMU advanced calibration, error identification and warning, reduced the impact of sensor error to the flight performance
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 04-26-2013, 12:40 PM   #8
zeeflyboy
Interesting, thanks for posting.
Any idea when it's coming? Looking at a new quad soon so might as well pick up the v2
Old 04-26-2013, 12:44 PM   #9
DebianDog
Nope no idea. I would imagine "soon" since a small group of folks are testing it.
