Old 11-29-2007, 12:32 AM   #1
G-Force Heli
Default Quad bearing upgrade for the DX7 gimbals by G-Force
For some time now the gimbals on my DX7 seem worn out and I have noticed some play. So I opened up the radio to check the tension springs. To my discovery, each gimbal only had a single ball bearing and a bronze bushing supporting it.
I have since replace all four bronze bushings with ball bearings. The radio now has quad bearings for each stick, two ball bearings for each axis.
It took me at least half an hour for each gimbal to be taken apart and reassembled. If you decide to do this, work very slow and carefully. There are a lot of wires to be aware of and don’t lose any screws or springs during the process.
All I can say is; it’s amazing how the sticks on the DX7 now feel more precise and smoother than it was new.
Garf
ID:	31843   Click image for larger version
ID:	31844   Click image for larger version
ID:	31845   Click image for larger version
G-Force Heli is offline        Reply With Quote
Old 11-29-2007, 12:54 AM   #2
fogger
Nice, may have to try this someday. Got a bearing size for us? (OD x ID x Width)
Thanks for the info,
-Fog
This heli stuff is a pretty deep Rabbit hole, you just have to decide how deep you are willing to go...
Check out my vids http://youtube.com/profile?user=wuestng
fogger is offline        Reply With Quote
Old 11-29-2007, 12:42 PM   #3
Skiddz
Bearing part numbers would be nice
-Kevin
Skiddz is offline        Reply With Quote
Old 11-29-2007, 12:52 PM   #4
flyboy320
Curious as to how long you had been using the TX for when the slop started to develop?
flyboy320 is offline        Reply With Quote
Old 11-29-2007, 01:17 PM   #5
piwko4
where did you get the bearings from?
piwko4 is offline        Reply With Quote
Old 11-30-2007, 05:01 PM   #6
Randallhurd
Cool Bearings/
I guess I'm going to have to break out the Micrometer tonight and work on that.
I have dang near ever size bearing out there with as many crashes as I've had in my first 5 months of flight.
I'm sure I can get something to work out.
I had a bad orientation problem last night,, But I guess that's good,, 30 flights and one Unplanned landing. :o
It was kinda dark out. Heli was about 100 feet away I though it was coming down Head first, when I moved the stick in what I though was the right way, I was very dissappointed 3 seconds later.
TREX600N Pro / ALL CNC
TREX600E ALL CNC
TREX450SE V2 ALL CNC
HDX300 PAPER WEIGHT
Randallhurd is offline        Reply With Quote
Old 11-30-2007, 09:31 PM   #7
G-Force Heli
The radio is a year old and gets heavy usage almost everyday. The sticks always felt loose since it was new. The bushing fit very loose on the gimbals so there no friction on the gimbals. The bearings fit snug onto the gimbals but are very smooth in operation, you can feel the difference.
Garf
Old 11-30-2007, 09:37 PM   #8
G-Force Heli
I am not here to solicit but to tell you all that the quad bearing gimbals are the way to go.
My HF id gives it away who we are.
Garf
Old 11-30-2007, 09:42 PM   #9
th3tick
Garf
Are you implying you'll be selling a set of bearings for this purpose?
Thanks,
John
Logo 600 3D V-Bar, Jazz 55-10-32, Tango 45-7, 0.7/13T, BLS451/BLS251, JR R921, Maniac623
Logo 500 3D V-Bar, Jive 100+LV, Scorpion HK-4020-1100, 0.7/15T, S9452/S9256, AR7000, RT560
T-Rex 600 CF, Jazz 80-6-18, Neu 1515/2.5D/F/H, 11T, S9451, ds760/S9254, AR7000, Radix600
T-Rex 500 CF, stock ESC/motor/rotors, 13T, HS-5245MG, ds760/S9254, JR R921
th3tick is offline        Reply With Quote
Old 11-30-2007, 09:50 PM   #10
G-Force Heli
John,
I am here to share with everyone my discovery how well the quad bearing upgrade works on the DX7. Keep in mind this has to be the most popular radio on the planet by now.
This simple upgrade is probably the best thing you can do for the DX7.
The bearings can be bought from any hobby store. We are not a hobby store.
Garf
Thanks,
John
Old 11-30-2007, 10:16 PM   #11
th3tick
John,
Garf
Understood, although you must not know how awful hobby stores are around the Denver area for random parts like bearings
Any chance at all you could share the bearing size used so we can all go find some?
Thank you,
John
Old 11-30-2007, 10:22 PM   #12
G-Force Heli
The bearing size is M4 x 7 x 2mm . I am sure any store selling micro helis would have this size. Some ball bearing servos use this size.
Garf
Thank you,
John
Old 11-30-2007, 11:01 PM   #13
ping
M4x7x2 is kind of a weird size. M4x7x2.5mm is the trex 600 flybar seesaw bearing is it too wide to fit?
ping is offline        Reply With Quote
Old 12-01-2007, 07:54 AM   #14
flyboy320
Has anyone found out the correct bearing size/part number needed yet?
Old 12-01-2007, 09:14 AM   #15
BarnOwl
Would G-Force be marketing those in a complete set with step by step instructions to do the conversion? I would buy such a set without thinking.
Jeroen -
Just fly it!
BarnOwl is offline        Reply With Quote
Old 12-01-2007, 03:25 PM   #16
aristo
http://www.vxb.com/Merchant2/merchan...egory_Code=4mm
abec 3's 6 bucks each,just ordered 2
aristo is offline        Reply With Quote
Old 12-01-2007, 04:00 PM   #17
flyboy320
I see those are 4x7x2 bearings. My local HS has 4x7x2.5 size ones for half that price. Anyone know if they would fit?
Old 12-01-2007, 04:02 PM   #18
ping
Those are open. I haven't found a source for a sealed 4x7x2's yet. I might try the 4x7x2.5 the next time my Trex head is apart.
Old 12-01-2007, 04:12 PM   #19
aristo
its inside your radio a sealed clean environment,sealed vs open makes no differance in this application.
Old 12-01-2007, 08:45 PM   #20
G-Force Heli
The 4x7x2 open bearing is fine. That is what I used.
The other ball bearing that is on the gimbals are also open.
