Old 12-04-2007, 09:45 AM   #1
gointoheli
Default Still having tail issue.
I know there are a million posts on tail issues and I've read through many of them but haven't figured this out yet. Before my first crash, but right after my first hard landing the tail becam erratic and wouldn't hold. I found that the screw that holds the ball onto the pitch slider was stripped. I tightened it as best I could and put some CA in there (per advice of LHS) and that seemed to solve the problem.
After crashing and rebuilding, the problem is back. The tail makes a strange whirring (sorry, can't think of a better way to put it) sound when you get up to speed and rudder inputs amplify the sound. When I lift off, sometimes it will immediately want to spin and sometime it will hover ok for a bit and then all of a sudden the tail takes off.
I've ordered a new pitch slider assembly to see if that is the problem but it just doesn't seem like it would be.
I'm running the 401/9650 combo. What sould the gain be set at on the 401? I think I have it at 0
Jody
Trex 600E CF
Trex 450 SE V2
Blade CX2
gointoheli is offline        Reply With Quote
Old 12-04-2007, 01:17 PM   #2
HeliSmith
Unhook the rod from the servo and hand spin it as you work the slider in and out. Binding? Bearings? Bent tail shaft?
I am using a DX7 and I have 72% in the gyro sense menu for gain, or right around that. I fly HH mode always.
(Compass Warp 360 w/Stock Motor (17t) running from a YGE60 governed at 3200RPM by the Vbar Black, sporting MKS DS95 on cyclic and JR3500G on tail)
Proud Field Representative for the following
HeliSmith is offline        Reply With Quote
Old 12-04-2007, 01:33 PM   #3
wespen
I discovered my shaft was just slightly bent when doing the tail mod.
One side has a hair clearance and another one was just rubing.
Was looking ok on spool up.
Wesp
wespen is offline        Reply With Quote
Old 12-04-2007, 01:55 PM   #4
gointoheli
I replaced the tail shaft after the crash but didn't really check the bearings. I guess that's a possibility although like I mentioned it was doing it before the crash. I guess it could have happened during the hard landing. I wish I could better describe the sound I'm hearing when it spools up. I know that when I hear that sound I'm gonna have problems.
I'm not using the gyro sensing on the Dx7. I have the gyro set to the gear channel using end points of +60 and -100 and have the gain on the gyro set to 0
I'm also using the stock metal control rod (but not using the supports) as I intended to get a carbon tube and haven't found one yet. I'm sure that is part of the problem with the tail being a little sloppy but doesn't explain the noise and why it wants to all of a sudden take off on me.
Jody
Trex 600E CF
Trex 450 SE V2
Blade CX2
Old 12-04-2007, 03:05 PM   #5
jaywhy
What does that mean exactly? Twitches to one side? Spins uncontrollably? If it's the latter, is it the tail pinion starting to slip? (Hmmm, that wouldn't *seem* to cause a noise though... )
jaywhy is offline        Reply With Quote
Old 12-04-2007, 03:20 PM   #6
gointoheli
A little bit of a twitch and kind of erratic but I think some of that may be due to running the tail rod with no supports. Then it will Just let go and start to spin counter clockwise.
Jody
Trex 600E CF
Trex 450 SE V2
Blade CX2
Old 12-04-2007, 03:25 PM   #7
gointoheli
It sound almost like the tail is not coming up to the same speed as the main rotor or it's lagging behind. You can hear the mains spinning up and then It's like as you increase throttle, the tail starts trying to catch up and you hear two distictly different pitches.
Jody
Trex 600E CF
Trex 450 SE V2
Blade CX2
Old 12-04-2007, 04:41 PM   #8
Super_Si
What condition is the belt in? It could be a bit loose, or maybe there's a couple of teeth missing.
Sorry if you've already checked, but it hadn't been mensioned so far.
Trex 450SE V2 (Black Carbon)
4x FlightPower EvoLite v2 2500mAh packs
Scorpion 2221-6 V2 w/ 11T pinion, CC45 ESC. 3500rpm HS!!!
Hitec HS65MG's on Cyclic. Trueblood Head Dampeners.
Futaba GY401 + S9257 (on 6v) + fireup's tail blade grip mod.
Super_Si is offline        Reply With Quote
Old 12-04-2007, 04:54 PM   #9
Lzfalcon
kickit23
Just a thought, is the gyro ok and or the servo may have lost it's centering cababilities? I had that happen on a hitec 6965 servo with a csm 560 gyro. The tail would make a whizzing sound like it was straining to hold center and would go crazy a few moments after. I went through some of what you went through and got frustrated until someone at our field suggeted the servo. The servo would work ok on the bench. I swaped out the servo and my problem went away. That's my experience.
good luck tracking down the issue.
"Just Fly It"
Raptor 90SE, Raptor 90, Thunder Tiger G4, 130X
AMA 819728
IRCHA 2259
Lzfalcon is offline        Reply With Quote
Old 12-04-2007, 05:20 PM   #10
Skiddz
Hold the mains still and try to rotate the TR. It should take quite a bit of force to get the belt to skip a tooth. (Don't go crazy TRYING to get the belt to skip a tooth as you might damage the belt) If you can move the TR without the belt skipping a tooth or the mains moving, you've probably got a slipping pulley or the hub is slipping on the TR shaft.
-Kevin
Skiddz is online now        Reply With Quote
Old 12-04-2007, 05:49 PM   #11
carlo_the_wonder_frog
I assume by 0 gain you are referring to the gyro gain menu being at 0? With the gear channel EPA's set to +60 and -100 it looks as though you have gain in HH mode of 60 and -100 in rate mode is this correct?
I would definitely check the bearings and also the 1 way bearing between the main and tail gears. A bad 1 way would make the noise you are describing and also if it is loosing its grip then it is unloading the tail and you will get a rapid spinning heli at random times. You might be able to just clean out the 1 way also and see if things improve, if they do then you know what the culprit is. My vote is on a slipping 1 way bearing.
carlo_the_wonder_frog is offline        Reply With Quote
Old 12-04-2007, 07:07 PM   #12
vetterick
I just had a twitching problem on mine, turns out the 401 is sensitive to noise from the ESC, had to move the ESC from where it had been for 100 or so flights with a Telebee, to under the frame to make a 401 happy.
If your ESC is anywhere near the 401, try moving it!!
That gouge on the head button? its from an inverted landing
vetterick is offline        Reply With Quote
Old 12-05-2007, 07:01 PM   #13
gointoheli
Thanks for the help everyone.
I figured it out. While replacing the pitch slider I noticed that the tail shaft was spinning but the gear wasn't. When I had my crash, I bent the tail shaft and LHS only had the one with the plastic gear. I figured it would get me by until the metal one arrived.
When I took the tail apart, I found that the right side of the gear was seperated and the gear was stripped and just spinning on the shaft. Not sure why that happened but replaced it and problem solved.
Thanks again!
Jody
Trex 600E CF
Trex 450 SE V2
Blade CX2
Old 12-05-2007, 07:04 PM   #14
gointoheli
Carlo, Thanks for the advice. My bad on the 0 gain on the Gyro as I meant to say delay was set to 0. You are correct on the EPA's
Jody
Trex 600E CF
Trex 450 SE V2
Blade CX2
