Old 12-05-2007, 08:37 AM   #1
huskynox
Default JR DS285 Mounting fix!!!
Anyone who has mounted DS285's to their 450 knows the mounting flange doesn't work too well because of the small recess in the mounting tab. I personally don't think it hurts the servo for that tab to flex a bit, and haven't heard of any ill effects, but still, it just bothers me.
I did some searching for a spacer or washer to fill that small gap and found the perfect fit! I found them at mcmaster.com. The part number is 90126A501. They run $1.15 for a pack of 100.
The indentation on the servo is .0240, these washers are .0205 thick. The OD (.219) and ID (.094) are perfect, so they fit perfectly in the recess - with the hole being perfectly centered (coaxial) to the hole on the servo.
Installation - take a small amount of Shoe Goo, tack the washer in place on the servo, then install the servo normally. Easy deal
Hope this helps.
See attached pics:
ID:	32190   Click image for larger version
ID:	32191   Click image for larger version
ID:	32192   Click image for larger version
500CF - 3650's, 3500G, Spartan, Stock ESC, Stock Motor, TP 6s Pro Power 2700mAh
PROTOS - 3650's, 3500G, Spartan, Scorpion 3026-880, ICE Lite 100, TP 6s Pro Power 2700mAh
600E - 8717's, 8900G, Spartan, Scorpion 4025-890, CC HV85, TP Pro Power 8s 3850mAh
Kasama Srimok - 8717HV's, 8900G, AR7100R, Spartan, YS 91SR, Hatori SB19
huskynox is offline        Reply With Quote
Old 12-09-2007, 02:53 PM   #2
kamtsa
Thanks Huskynox.
I encountered the same problem and luckily decided to search here for a solution.
Kam
kamtsa is offline        Reply With Quote
Old 12-11-2007, 02:08 AM   #3
teshreve
I used the little plastic nuts that came with the heli.
They fit PERFECTLY in the servo tab holes and don't even rotate due to the flat side on them. They seem to be custom designed for the 285 servos. Or perhaps the 285 servos were designed for the nuts
Either way, they work friggen awesome together.
teshreve is online now        Reply With Quote
