Go Back   HeliFreak > R/C Helicopter Support > HeliDirect
HeliDirect HeliDirect HDX300, 450, 500, 550, 600 Factory Sponsored Support Forum
Old 12-07-2007, 03:31 PM   #1
enry74hh
Default Max Range pitch -9 / +9; ???????
I had a 3DX500; using whole movement Swashplate it reached a range pitch +12 / -12
Now I bought a HDX500SE; using whole movement Swashplate get a pitch range maximum +9 / -9 .
What is your pitch range?
Have you made changes?
Thanks.
enry74hh is offline        Reply With Quote
Old 12-10-2007, 05:18 PM   #2
aussiemick
I had about 9.5'+- with my HDX500 when it came as standard
I swapped over the top half of the head and turned it into a 3DX500 !
I had to dial the collective pitch back to just under 10' because I was stripping maing gears all the time. I bought a few Lepton main gears and they handle the power a bit better but still can't put full pitch at it, Tic toc's are especially tough on the main gear I have found.
Mick
aussiemick is offline        Reply With Quote
Old 12-11-2007, 03:53 PM   #3
enry74hh
Even I had on 3dx500 the same problem com +-11
I solved main gear changing. Now is a gear mudulo 1 with 60T / 15T.
Now I have no more problems.
Enrico.
ID:	32585   Click image for larger version
