Go Back   HeliFreak > Multi Rotor Support > Main Forum - Multirotor Talk
Main Forum - Multirotor Talk General Multirotor Support
Old 05-21-2013, 11:03 AM   #1
Sladex
Default DJI NAZA Issue. Tx not connecting.
Hey so I am using a ar8000 and I bind it to my dx8 but when I supply power to the mc I get the red flashing light then when I plug it in none of my tx controls appear on the software. I'll show you a picture of my wiring to make sure I did it right. I read the manual over and rover again to make sure I did it right but I'm still confused.
ThanksImageUploadedByTapatalk1369148536.320145.jpgImageUploadedByTapatalk1369148558.232565.jpg
Sladex is offline        Reply With Quote
Old 05-21-2013, 01:32 PM   #2
z_man_95
Are you binding the receiver, then hooking it up to the naza?
I hooked my ar8000 to the naza, then power up the naza/rx, and bound it to my dx8 with no problems.
I put the bind plug in, power it up, remove the bind plug, set my tx for failsafe (programmed fail safe switch on fail safe, throttle at midstick) and then power up the tx while holding the bind button down.
Hope this helps.
edit: Also while binding, try keeping the tx at least arms length or more away from the rx.
z_man_95 is offline        Reply With Quote
Old 05-21-2013, 01:42 PM   #3
petedee
If the VU light does not go green when you plug in the USB cable then the driver is not working.
similis vobis fugere eam furatus
"The beatings will continue until morale improves."
-- William Bligh
petedee is offline        Reply With Quote
Old 05-21-2013, 02:33 PM   #4
Thalios
Is your Naza set as traditional as receiver mode?
Thalios is offline        Reply With Quote
Old 05-23-2013, 01:38 AM   #5
Sladex
My solution was a faulty sx. Thanks for the help the naza is solid now.
Old 05-23-2013, 03:37 PM   #6
petedee
Faulty sx, what is an sx?
Pete
-- William Bligh
Old 05-26-2013, 12:23 PM   #7
Sladex
It's a satelite
