Old 05-28-2013, 02:33 PM   #1
St@rbucks
Default MicroHeli Hop Ups
Hi.
Anyone have anything bad or good to say about the Microheli alu uppgrades to the 300 x?
I'm thinking about bying parts to bling up my heli.
Or should i stick to the alu parts fro Horizon?
Cheers
St@rbucks is offline        Reply With Quote
Old 05-28-2013, 07:33 PM   #2
xpantz
I would give most of the Blade hopups a miss... expensive and usually not as good as the plastic bits. There are plenty of threads here regarding the swash and tail case in particular.
If you have to bling it... go for one of the others... Lynx, Microheli, KDE etc
Geoff
Align trex based 450 dfc (6s) x 2 - 300x - mcpxbl - Aimdroix EVO - TBS Discovery - rctimer Spider - Flip Sport - QAV250 - ZMR250 - Warpquad 230 - Alien 4" - Alien 6">watch this space<
xpantz is offline        Reply With Quote
Old 05-29-2013, 08:13 AM   #3
d12bn
I've been testing Microheli upgrades for months and all the released parts have performed well.
Team Microheli Team Scorpion Team Boca Bearing Team Revolectrix
Check out my Heli Pilot Shirts https://teespring.com/stores/rc-heli-pilot-shirtsMy Youtube channel
http://www.youtube.com/user/JJInvert...n?feature=mhee
d12bn is offline        Reply With Quote
Old 05-29-2013, 09:41 PM   #4
sharicasmi
just the Lynx or Asteriod design frame stiffener, and the microheli main gear hub with one way bearing. I've mentioned before on other threads how my Jesus bolt one day broke inside the shaft because there's no one way bearing and alot of pressure is put on it when the heli is spooling down.
Just because it's metal and has thrust bearings, I'd also recommend
Nano CPX x2, MCPX BL, HP05 MCPX(retired), 130x, Trex 250 SE(retired), Blade 300x, Trex 450 SA, Blade 450x, Trex 450 PRO, HK500 CMT(retired), Blade 500 3D, Assault 700 DFC
sharicasmi is offline        Reply With Quote
