Go Back   HeliFreak > R/C Simulators Support > Reflex Flight Sim
Reflex Flight Sim Reflex Simulator Talk
Old 12-14-2007, 06:57 PM   #1
ericmf
Default Reflex Sim Futaba cable adapter
I have a reflex sim cable that comes in two parts. I am having a lot of trouble with the short cable in the picture with the square connector for a Futaba T7CAP Transmitter. There is a bad connection that I can't seem to fix. I do not believe it's the transmitter connection as I've tested that thoroughly. I've also opened the square connector and re-soldered the connections but no help.
Has anyone else had the same problem? is there a resolution to the problem or better cable supplier?
ericmf is offline        Reply With Quote
Old 12-16-2007, 11:57 AM   #2
theglennster
Eric the Reflex cable should be OK although I although ther is only one cable that plugs into the USB dongle. I could imagine it could easily have a broken wire inside as they do tend to get dragged about a bit. What is your exact problem the TX should turn itself on if you plug the lead in if not then you have a problem and maybe a faulty dongle that Reflex will replace Free of Charge.
Do you have a picture of it ?
T-Rex450SE, FBL Align 3G system
T-Rex600E, FBL Align 3G system
T-Rex700E, FBL Align 3G system
Hirobo Quark & a few PLANKZ, Extra 260, Akromaster...
Yamaha YZF-R1
theglennster is offline        Reply With Quote
Old 12-17-2007, 07:59 PM   #3
ericmf
I actually was able to fix my connector. There are only 2 pins used, so I heated those two pins and pulled them outwards. I had to melt the plastic before pulling.
anyway the connection works better now.
Thnx for the advice
