Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters
Scale Helicopters Discussions About Scale Helis, compatibility and and projects
Old 12-22-2007, 08:59 AM   #1
Darren S
Default electro skaler help
hi guys,
i have just begun to assemble my Graupner Heim Electro Skaler mechanics. it has a Compact outrunner motor that is rated at 385 kV. it comes with two different pinion gears. at 28 tooth and 32 tooth. there is a secondary gear drive so the gear ratios work out to 7.5 to 1 and 6.75 to 1 respectfully.
my problem is this: on a 10 S setup the calculated headspeeds will be in the 2200 rpm range. WAY TOO HIGH for scale flying.
my question is this : how do i get around this ? do i use the throttle curve to slow the head down ? i think this will cause overheating issues as brushless motors are designed to run at near 100%.
please shed some light.
thanks, darren
Darren S is offline        Reply With Quote
Old 12-22-2007, 09:01 AM   #2
frebou
get a smaller pinion... it will reduce head speed. What blade lenght are you running and how much is the whole model weight?
frebou is offline        Reply With Quote
