Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters
Miniature Aircraft Helicopters Stratus, Spectra G, Furion, Ion-X, Bobby Watts
Old 04-24-2005, 05:29 PM   #1
mike15
Default problems with grub screws on 15t pinion
hi
for some strage reason my pinion gear has moved forward. So i went to loosen the grub screws but they nackerd the allen key just spun round. So can i drill them screws out and then re tap them and put bigger grub screws in.
mike
mike15 is offline        Reply With Quote
Old 04-25-2005, 04:18 AM   #2
sdixon747
I believe the grub screw is 1.5mm hex. If your 1.5mm allen key slips, try a standard 1/16 allen key. It is slightly larger (1.5875mm) and sometimes gives that extra grip needed. You can also use a little heat to loosen up the Locktite.
Hope this helps
Steve
sdixon747 is offline        Reply With Quote
Old 04-25-2005, 09:41 AM   #3
DavidH
The suggestion Steve made will work. I suggest use allen drivers with hardened tips and not the cheap L shaped allen wrenches. They are soft and will just mess up the screw inside the socket.
David
DavidH is offline        Reply With Quote
Old 04-25-2005, 01:22 PM   #4
Dr.Ben
Another tip:
EVERY time you have to pull 2mm set screws out that have been fully torqued with loctite, throw them in the trash and install fresh ones. You can buy a box of them from MSC or the like making them cost about a few cents each, a lot less than the heartache you're having now. Get some high quality drivers to just as David suggested.
Ben Minor
Team Futaba Team Synergy Field Representative Team Kontronik USA
Dr.Ben is offline        Reply With Quote
Old 04-25-2005, 11:52 PM   #5
3DME
Hello
I use the Whia brand tools and they last for many years and are very hard. They are not cheap but you will only buy them once if you can keep from loosing them like I do.
Mike
I am Mike Jones biotch
3DME is offline        Reply With Quote
