Go Back   HeliFreak > For Sale Forums KNOW your buyer/seller ratings! No Price bashing. NO FIREARMS > Electric Helicopters - Only E-Helis
Electric Helicopters - Only E-Helis *No Commercial Ads - E-helis Only
Old 07-14-2013, 08:19 PM   #1
bikerlee
Default Logo 400 SE
Selling my Logo 400SE. Had this for about a year and has 454 flights and a couple of crashes.
Every part that was damaged in each crash was replaced with new Mikado parts.
The Fusuno tail fin has a crack in it but I am including a new Mikado one in the spare parts.
I did remove some of the heat shrink that covers the ESC for better heat dissipation as well as cover the caps with Shoe-Goo to stop them from moving and braking the solder joints.
ESC - YGE 80LV with V-Bar gov wire.
BEC - Hobbywing 5A UBEC
Cyclic Servos - Futaba S9650
Tail Servo - Futaba BLS251
Motor - Scorpion 3226-1400kv
Blades - Edge 473mm FBL B surface
Tail Blades - Edge 86mm SE
FBL CONTROLLER AND SAT ARE NOT INCLUDED IN THE SALE.
Also including some spare parts which include: landing gear, cyclic servo rods, tail fin, bearings, tail gear, 2 main gears, 3 tail shafts & pinion for going down to 423mm blades. I also have a couple of 400 tail booms if you want to make it a 400 size.
The blades are B surface and have a few marks on them, purely cosmetic.
Machine flys incredible, very light with tons of power and super fast.
It's in pretty good condition, the canopy has some chips in it on the underside but looks great on it.
I also have 5 Sky Lipo 3000 mah 40C packs that I can include. The packs have between 60 and 102 cycles, can provide each packs cycle if wanted. The shrink wrapping is scuffed up and coming away on the end of one of them but they all provide great power, can't tell the difference between the older and newer packs. One cell on one pack is just starting to not quite balance out but doesn't seem to affect it's performance too much. Paid $60 for each one.
All up it's got about $1,050 in to it without the FBL controller, looking for $750 shipped and PP. Will ship it in it's original box but will need to take it apart. Add another $150 for the batteries.
ID:	435722   Click image for larger version
ID:	435723   Click image for larger version
ID:	435724   Click image for larger version
bikerlee is offline        Reply With Quote
Old 07-14-2013, 08:20 PM   #2
bikerlee
Some more pics...
ID:	435726   Click image for larger version
ID:	435727   Click image for larger version
ID:	435728   Click image for larger version
Old 07-19-2013, 09:54 AM   #3
bikerlee
bumpity bump...
Old 08-07-2013, 01:42 PM   #4
bikerlee
No main blades now but price drop to $650 for everything listed above.
Old 08-28-2013, 09:21 AM   #5
bikerlee
Okay, back with FB blades, $650 for the whole lot.
