Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters > Zoom/Shogun 400
Zoom/Shogun 400 Electric - Zoom - Shogun 400 Specific Discussion
Old 04-30-2005, 06:48 AM   #1
pey
Default crazy tail servo
hello
I have a problem with my tail servo,itīs gone crazy. When I increase throttle it glitches like crazy. but only throw the gyro..Sow itīs not servo problem. when the gyro is not in contact with the heli everything stops.
what can it be? its driving my crazy need help please. thanx
pey is offline        Reply With Quote
Old 04-30-2005, 08:17 AM   #2
waynekinney
Sounds to me like vibration interfering with the gyro. Are your blades balanced? Do you notice any bad vibes? Also, is the gyro mounted in special vibration dumpening foam?
Wayne.
waynekinney is offline        Reply With Quote
Old 04-30-2005, 08:53 AM   #3
pey
hi. i dont see any bad vibs on it. I guess its got the usual vibs, they stop when head speed is good. blades are balanced, no tracking. I tried using some foam sticked on gyro but still the same.
Old 04-30-2005, 10:30 AM   #4
waynekinney
what gyro is it?
Wayne
Old 04-30-2005, 12:13 PM   #5
pey
gyro is piezo 310. i`ve been flying with it for 2 months whith no problem. The guy at the shop told be it was my brushed engine, but now i`ve put on a hacker b20 15l and have the same problem. thanx for those quick replies.
Old 04-30-2005, 05:49 PM   #6
waynekinney
is your gyro close to your esc? some have reported interference if too close. try moving the gyro as far away from the esc as possible.
wayne.
Old 05-01-2005, 04:52 AM   #7
tnreefguy
Mine does the same thing. do you have the tail servo and gyro mount? If not order that, and the diy tail pushrod kit. It really calms the tail down by getting rid of all that slop. The tail control on the shogun is crappy stock but the upgrades that are available really stiffen it up. I ordered mine from Mjp carbon.
tnreefguy is offline        Reply With Quote
Old 05-01-2005, 06:01 PM   #8
pey
gyro is taped on the side of heli ,above pith servo. It worked for two months and suddenly started to glitch. I guess its just broken. waiting for those up-grades. What gyro should I get? ,heading lock? is it usefull?
Old 05-01-2005, 06:09 PM   #9
tnreefguy
all i have ever used was a heading hold gyro and futaba its really a matter of pilots choice.
