Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 08-01-2013, 06:07 AM   #1
blom
Default 450 3D need motor bearing mod?
I"ve searched but those skills are about as well honed as my flying abilitys. Does the 450 3D need the motor mod like the 300x and 450x?
blom is offline        Reply With Quote
Old 08-01-2013, 06:24 AM   #2
Skidpad
Default Re: 450 3D need motor bearing mod?
Yes, it has the same problem. That being said, some people have very good luck with them after doing the Loctite mod
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8. Team Lynx Heli Innovations Pilot
Skidpad is offline        Reply With Quote
Old 08-01-2013, 08:00 AM   #3
Gladius
Has anyone had any issues with the 450H motor? Does it also need the lock tight mod?
<> Trex 600 ESP FBL, Trex 500 ESP FBL, Gaui X3 <>
<> Builds in progress: Logo 600SX, KDS Chase 360 <>
*Spartan Vortex VX1e*
Gladius is offline        Reply With Quote
Old 08-01-2013, 08:24 AM   #4
Inverted2112
I don't have one yet, but from everything I've heard the 450H is solid right out of the box and is what I plan on putting in my 450X and converted 450 3D when the time comes.
Current favorites...
Oxy 3, Goblin 380, Logo 400SE, Logo 480Xx, Goblin 500, TBS Gemini, 250 FPV Quad Racers, bunch o' Planks, etc..
Inverted2112 is offline        Reply With Quote
Old 08-01-2013, 06:47 PM   #5
hogrider400
Okay Ill bite what is the motor mod on the 450 3d ?
hogrider400 is offline        Reply With Quote
Old 08-03-2013, 04:56 AM   #6
blom
I'm really to much of a newb to give you a good answer but if you search the 450x threads it's explained very well, even a top notch video on how to do it. Now I've got four of them to do.
Old 08-03-2013, 10:05 AM   #7
Gladius
You loctite the motor shaft to the bearings. Otherwise, the shaft spins within the bearings, causing both to wear out.
Old 08-03-2013, 08:26 PM   #8
Neunerball
It's the same as for 450x, 300x see: http://www.helifreak.com/showpost.ph...66&postcount=8
"Nothing is as constant as changes"
DX9, DX6i, Blade Nano CP X, ZYX "Blade" 130X, Blade 180 CFX, Blade 230S, Blade 300X, Blade 450 3D (about 2 b FBL; have the parts, not the time), Blade 180QX
Neunerball is offline        Reply With Quote
Old 08-04-2013, 11:07 AM   #9
AUSS1E
Problem with the mod is that when the bearings do wear out it is about impossible to get the motor apart to replace them. Ask me why I am looking for a new motor!!
AUSS1E is offline        Reply With Quote
Old 08-05-2013, 02:05 PM   #10
Gladius
So you can choose to not do the mod, and look for a new motor after 50 flights, or do the mod, and look for a new motor after 200 flights!
Old 08-07-2013, 10:27 AM   #11
LubeMan1
Or Just run it till it gets bad then replace the bearing set with Boca's...Wasn't hard to change
LubeMan1 is online now        Reply With Quote
Old 08-08-2013, 09:58 AM   #12
youngb87
So this questions was asked, and kinda got an answer, but does anyone actually have the motor (E-Flite 450) and confirm that its not in need of the bearing mod?
And will the stock ESC work fine with the 450?
youngb87 is offline        Reply With Quote
Old 08-12-2013, 06:15 PM   #13
OGMiller
Mine failed as well with less than 20 packs through it and that was during my learning to hover. I was able to take mine apart and chuck it in the lathe and bored the center housing to hold a "sleeve" of bearings so to speak.
The motor shaft was worn where the original bearing was so I bored behind it for another bearing the same size and behind that for one with a slightly smaller O.D. then where the OEM bearing was a left another OEM size one in and then shimmed up to the circlip with vriouse pieces from a hardware bag for the blade 450.
I"ll try and post some pics of what I've done, but after at least 30 more packs the motor is still fine as of checking it last night.
I also used "stud and bearing" loc-tite to secure the shaft into the new bearigns as well as the new bearings into the housing
I'm new to heli's in general so I was un-aware of this when I bought the bird last month but this fix has been great, I know i'm new here but if anyone would like their motor repaired in the same manner i'd be glad to do it on the dirt cheap (I have plenty of forum references for my mail order work as it's all I really have since being on disability these days) (feel free to ask about turboglenn on the DSMtuners forum for any references to my character or reliability) *i'm not offering this to make money but to simply offer a fix that's a little better than basically "glueing" the motorchaft to the bearings: for anyone wanting it done)* (i'm u8sing a new screen name here to keep my stalker of an Ex-wife from hunting me here as well LOL )
OGMiller is offline        Reply With Quote
Old 08-12-2013, 10:36 PM   #14
FuntanaS
No, because the motor shaft gets worn out. At that point the motor is essentially junk.
Tarot 450 Pro V2 FBL - Blade mCP X - Blade 450 3D FBL
FuntanaS is offline        Reply With Quote
Old 08-13-2013, 05:20 AM   #15
Gladius
Was this with the stock 420 motor that comes in the 450 3D, or with the aftermarket 450H motor?
Old 08-13-2013, 05:59 AM   #16
OGMiller
i'm sorry this was witrh the stock motor, being new to heli's I am not use to motor variations this small, when I was into electrics last there was the Mabuchi 360 and 540 sizes and that was it (can you tell i'm getting old LOL)
but If there's not been a change to shaft size or bearing quality and possibly it's I.D. then I would assume this would be a possible failure on any motor with these specs.
I've put about 8-10 packs a day on this repair for the alst week and it's holding great though for what it's worth..sorry again for the confusion
Old 08-13-2013, 09:30 PM   #17
wehlke
My first 420 motor shaft spun in the bearing too after a couple months. I replaced it with a 440 about 6 weeks ago and used blue loctite before I installed it. I have started a fair bit of 3D and now the 440 spun too.
Horizon Hobby is sending me a new motor but said they had not heard of it before and had no suggestions to help it last longer. They are sending me a couple spare bearings. They said PN BLH 4534 is the motor bearing and it is 3X7X3. It is a bearing for somewhere on the 300X
I am going to try the green loctite this time and hopefully I can salvage this motor for a spare.
wehlke is offline        Reply With Quote
Old 08-13-2013, 09:44 PM   #18
FuntanaS
If I were you I would sell that new motor and put that money toward a better motor. Like the E-Flite 450 or a Scorpion.
Old 08-13-2013, 09:52 PM   #19
wehlke
I am very tempted but do not want the expense of upgrading the ESC too. It works great so I am going to give it another shot and try to make it last.
Old 08-13-2013, 10:11 PM   #20
wehlke
I have noticed several different 450 Eflight motors. Which part number are you referring to and how many amp ESC does it need?
