| 600 Class Electric Helicopters 600 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Hey,
I have a 600 E I upgraded my servos for stronger ones but they seem to be a bit to big for the aileron and pitch servos when i push them in (one against the other) i must put spacers to space them from the CF main frame. What do you suggest I do? |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
I think Finless mentioned in his T-Rex 600N videos that the 600E required spacers, so you may have already done what needs to be done (use spacers).
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
Yes but there is still way to much space!
Thks anyway |
They're very deep servos - what are they ? - you obviously have to fill up that space - you can order CF spacers from Align or else make something up yourself - you want to try and keep the pushrods as parallel as possible and looks like you will have to mount the ball links under the servo horn and outside on the bellcrank. If you have an issue relating to a specific helicopter you will get better advice if you post it in that forum. (T600E)
John |
Thankyou very much
I think i might make spacers myself thks for the advice cya |
#6 |
Hi Big,
In the following thread you will find quite a bit of info regarding spacing servos out. I had a bear of a time getting my BLS451s to fit. http://www.helifreak.com/showthread.php?t=53377 Good luck to you and keep 'em flying. LJS
Logo 600 VBar, X4030-560, 12T, 10S 4500, Jive 80HV, 8717s/8900g, WR5A, GB 620s TRex 600E VBar, X4025-830, 17T, 8S 4200, Jazz 55-10-32, BLS451s/BLS251, WR5A, RT 600s Logo 500 VBar, S4025-1100, 16T, 6S 5000, Jive 100LV, 9452s/8900g, WR5A, SAB 550s TRex 600ESP (auto special), S4025-1100, 16T, 6S 5000, Jazz 80-6-18, DS610s/DS620, DS760, WR5A, HD600s |
#7 |
Hi again,
Another thread that you might find helpful is this one on a canopy bumper modification. Once you space your servos out, you will find that the horns hit the canopy. This mod helps a lot. It also helps tighten down a loose fitting canopy. I love this mod. http://www.helifreak.com/showthread....canopy+support LJS
#8 |
Hi
actually i just made little wood spacers and i adjusted the servos in with sand paper works good but cant get the caopy on without interferences!! |
#9 |
Careful now adding wood to your heli. Wood is reserved for planks. LOL
Sounds like you have it figured out. Just need the canopy spacers now. Please don't use wood for these as well. LOL Seriosly now. I have planes as well as helis and wood is fine. I just have issues using it on my helis for some reason. Strictly personal preference. My largest (and most favorite) plane is worth more than one of my rexes and is all made of wood. Best of luck.
Conway V Scene From Above Photography To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Logo 600SE Cameraship, Logo 600SE, Compass 7HV |
#10 |
u maybe want a pic of how it looks?
I think I'll just try flying without the canopy thks |
#11 |
Hi BigTrex600,
You're going to fly it without the canopy??? But isn't part of the joy seeing your beautiful heli in the air? It's not quite as beautiful without the canopy. Try the Align servo spacers to space your servos out just far enough, add the Align servo horns, and then put on the canopy bumpers and you'll likely have clearance. It would break my heart to have to fly without my canopy! Keep 'em flying. LJS
#12 |
The spacers dont work
2 spacers aren't enough and 3 is to much I'll try and figure out something but you think wood is ok or not good? |
#13 |
What about the aluminum spacers that came with the kit? They're about half the height of the carbon fiber spacers. I'm using two CF spacers and one aluminum spacer under each mount on my BLS451s.
Yes, wood should be OK. Do you have a means of making it precisely the right height? Sanding or cutting with an Xacto are not that precise. Good luck to you. LJS
#14 |
I think I might use that
but i got to buy the Cf spacers would you like a pic and data on the servo? |
#15 |
Yeah, that would be great.
Thanks, LJS
#16 |
Here,
I got these servos in a shop in france they were destocking i got four for about 50 dollars actually I'm from switzerland anyway here is the data: A2pro HT-5512 servo 5.5kg/cm on 4.8 volts 0.19 sec/60 degrees dim. 41*20*41 cm 64 grams 2 bearings metal pignons |
#17 |
Hi BigTrex,
Hmmm. You're kind of in uncharted territory with those servos. Here's a link to the page for the servos that I have. If you click on the picture of the BLS451 servo, you'll see the dimensions of my servo. I had to work really hard to get those to fit with the canopy on. I only have about 2 mm clearance between the servo horn and the canopy on one side. But I had heard that other guys were making it work, so I was inspired to do the same. http://www.futaba-rc.com/servos/brushlessservos.html If your servo dimensions are similar to mine, then it should fit. If they are significantly larger in any respect, then I don't know how you'll get enough clearance for the canopy. One option I considered was cutting holes in the canopy for clearance. My Swift has a hole in the canopy for cooling, and I really never notice that it's there. Holes might be a good solution for you. Good luck and keep 'em flying. LJS
#18 |
Sorry about the wood Joke. I guess it is more of a personal thing with a couple of the guys here. Heli flyers are always bugging plankers and vice versa. For that reason alone I don't mix the 2 up. Would have to some fancy explaining if my fellow heli flyer saw wood on my heli.
That being said, there is nothing wrong with wood if it is precise, like was already mentioned.
