Old 08-10-2013, 07:59 PM   #1
heliface
Angry Throttle hold unreliable on the Nano CP X?
Hi,
So i had some bad crashes today that were made about 11ty times worse by the throttle hold failing to engage. What usually happens is i see the nano is heading for a tree, or the ground and I hit throttle hold. But instead of the motor cutting out, the motor continues to run and sends the heli full force into the ground. It then flips around on the ground for a few seconds before finally cutting out, probably doing even more damage in the process.
I've read somewhere that lvc might have something to do with this behavior, but it's been happening to me at the beginning of flights as well as the end, and with about a dozen different batteries that were bought at different times.
I've also noticed this behavior with the original msr back in the day. Looks like it's a horizon hobby problem that spans all HH products?
heliface is offline        Reply With Quote
Old 08-10-2013, 09:47 PM   #2
GoatRider
Are you using the stock transmitter? I've heard the TH is pretty dodgy on that.
LVC, once it's started, ignores the throttle channel and just slowly ramps down the power. If you don't manage to land nicely during that, it's going to chicken dance and there's nothing you can do about it. Except for set a timer and never let it get to LVC, it's bad for the batteries anyways to let them get that low.
- Benton Jackson, Maple Grove MN
Roswell Flyer (retired), Concept EP (retired), Eco 8 (retired), WLToys V929 & V202, Nano CPx, Nano CPx mild BL, Nano QX, mCX2, 130x
GoatRider is offline        Reply With Quote
Old 08-10-2013, 11:12 PM   #3
pixeltim
+1
My aerial photos are at pixeltim.com
Phantom 2 Vision and assorted other egg-beaters.
pixeltim is offline        Reply With Quote
Old 08-10-2013, 11:37 PM   #4
65L88
Another +1 to the above. And if you have other than the stock transmitter (ie, dx6i, dx7, etc), I'd check my throttle hold settings first, and if all is well, try a rebind.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- 300X - 130X X3- mCPX brushless X3-Nano cPX X 2- Nano QX
65L88 is offline        Reply With Quote
Old 08-11-2013, 01:01 AM   #5
vtown nick
Omg I started out with the DX4e and the throttle hold is a joke on that!
The amount of parts you will replace due to the th not working will justify a DX6i
TmkaRc1Hobby Team Support
Team MSH USA -
Cyclone Blades
MSH Prtos 380 Brain 2
vtown nick is online now        Reply With Quote
Old 08-11-2013, 04:38 AM   #6
heliface
I am indeed using the stock tx. So you've experienced similiar behavior where pushing the th button seems to have no effect?
Old 08-11-2013, 07:23 AM   #7
gstoneberg
As I recall, TH doesn't take effect until the button is released on the dx4e. I had a very hard time remembering to release the button in the panic of the impending crash. Pushing it was no problem. The dx6i is much better and really helped my flying.
George
gstoneberg is online now        Reply With Quote
Old 08-11-2013, 09:52 AM   #8
vtown nick
Correct, even when I would press and release most of the time it wouldn't work. This tx doesn't have any expo either so when you do flips its all over the place. It's truly night and day a different heli with a computer tx. Plus you can set a timer so you don't kill your lipos
Team MSH USA -
Cyclone Blades
Old 08-11-2013, 11:20 AM   #9
GoatRider
Actually the DX4e has a mode where you can give it a fixed amount of expo, 25% I think. The directions aren't in the DX4e manual though, they're hidden in the HyperTaxi manual, on page 10:
http://www.horizonhobby.com/pdf/EFLU4780-Manual-EN.pdf
Old 08-11-2013, 03:13 PM   #10
vtown nick
Nice find!
Team MSH USA -
Cyclone Blades
Old 08-18-2013, 02:34 AM   #11
seth1846
I've never used that radio but adding but not describing a crucial feature of a radio is just plain wrong...... Lol
seth1846 is offline        Reply With Quote
Old 08-19-2013, 08:13 PM   #12
Fragtastic Reef
It may not be the TX at all, on my first Nano CPx the main board went bad after only a few flights and had it replaced. After about 2-3 minutes of flight it was still have power but just fall to the ground and main blades would still be going even with TH engaged. Might want to see if the board on yours is bad....
Fragtastic Reef is offline        Reply With Quote
