Old 01-04-2008, 12:10 PM   #1
sky-t
Default Radix Blades question? Help please.
Hi,
I have brand new 600mm Radix blades ready to be installed on my T-rex 600 E. I have the Metal blade grip upgrade. My question is how do i mount the blades, i recieved 4 big round washers with the blades within the radix box, do i have to use them? The blades seem to be fitting into the grips just perfect without the washers, though will the holes get torn if i do not use the washers? I'll have to use a bit of effort to fit the blades with the washers, don't want to strecth the grips though using the washers, how should i do this? There were no instructions with the blades.
I will really appreciate any help, the heli is so almost ready to fly
Old 01-04-2008, 12:15 PM   #2
fogger
No washers are required for use with the 600. They are for helis with 14mm wide grips.
-Fog
This heli stuff is a pretty deep Rabbit hole, you just have to decide how deep you are willing to go...
Check out my vids http://youtube.com/profile?user=wuestng
fogger is offline        Reply With Quote
Old 01-04-2008, 12:17 PM   #3
sky-t
Fog, you just made me smile ! thanks, now i only have to bolt them down with the bolts supplied with the grips !! thanks again! This one's going up i never want to bring it down hehehe!
Old 01-04-2008, 06:01 PM   #4
aucmax
A second thumbs up from me too. I had the same question when I received my set.
Not one of us is as smart or knowledgeable as all of us bonding together.
Brett
aucmax is offline        Reply With Quote
Old 01-05-2008, 08:14 AM   #5
sky-t
thanks ! now do i need to store my heli with the blade extended or should they be folded and tugged into the blade holder on the boom, also i noticed the metal grips makes its markings on the blades, a circle, i don't like it, though i already installed them, o thy must be used... thanks all!!
Old 01-05-2008, 08:21 AM   #6
growler
Hey Sky-t.
I see you in SA. Me too...where abouts in the country are you?
Hope you enjoying your 600!
Trex 450SE, 4S, Jazz 40-6-18, Scorpion 2221-8 V2, 10T, HS-65MG, Mini VBar/S9257
Trex 600CF, 10S, Jive 80HV, Scorpion 4025-740, 16T, Align 610's, JR G770 3D/JR8900G, AR9000
Knight 600E, 10S, Hobbywing 100A-HV, Scorpion 4025-630, 10T, JR8717's, JR G770 3D/JR8900G, AR7100
Trex 700CF, OS 91HZ, JR8717's, Rondo fbl/JR8900G, Switchglo, AR7100R
growler is offline        Reply With Quote
Old 01-05-2008, 05:06 PM   #7
Mercuriell
Folding them is fine - your grips shouldn't be done up super tight - just stiff
John
Mercuriell is offline        Reply With Quote
Old 01-05-2008, 08:00 PM   #8
bullaculla
I usually loosen mine before I fold them up. then tighten them again while folded.
T-Rex 600 HFE-stretched to 700, 10s, Tango 45-08, Jazz 55, JR7703D/S8900G, DJ Vegh nose cam mount.
T-Rex 600 HFX-stretched to 700, 10s, Orbit 30-12, Jazz 55, GY611/S9256, Askman 360 mount.
JR X9303.
bullaculla is offline        Reply With Quote
Old 01-05-2008, 08:12 PM   #9
SFACV
Curious, does it wear out the plastic in the locknut and get easier to turn.
Conway V
Scene From Above Photography
www.scenefromabove.ca
Gaui X7 Cameraship
SFACV is offline        Reply With Quote
Old 01-05-2008, 08:24 PM   #10
bullaculla
Nope. Just a quater turn wont hurt.
But I usually take off the blades completly while traveling. I keep 2 new sets of blade bolts in my blade case just in case.
JR X9303.
Old 01-05-2008, 08:31 PM   #11
SFACV
What do you do with your flybar? This is my biggest PITA. Always out there to snag on something or I bump it against my leg. Can't wait to go flybarless.
Conway V
Gaui X7 Cameraship
Old 01-12-2008, 08:58 AM   #12
sky-t
Thanks Can one test the T-rex 600 blades like the 450 ie. turn the heli on it's side and the blades should not fall under it's own gravity, will that be the "ideal" stiffnes for the blades when tightened?
Growler Hi, yip i'm here....... in the randburg area, and you? I also have a 450 and fly at the sports field every now and then.
But i mostly fly E-planes there.
Old 01-12-2008, 02:19 PM   #13
bullaculla
Yep, thats how i used to check it, but after awhile you just know when its tight enough. I still spend extra time to make sure they are both the same tightness tho.
JR X9303.
Old 01-14-2008, 09:40 AM   #14
nadavbarak
Default Hi sky-t, we use 600 Radix blades also for Alon's Trex600e...
we also use 10S Thunder power batteries.
the heli is so strong.
much more than any other 90 nitro heli.
the radix works just fine, and spins more than 2300 rpm.
we are about to try the 600 "Stick Bangers".
any way, you dont need to use the washers.
Best Regards,
Alon & Nadav Barak.
nadavbarak is offline        Reply With Quote
