Go Back   HeliFreak > Multi Rotor Support > Flight Controllers (NAZA, Wookong, A2, etc...) > DJI Multirotor Forum(A2/WKM)
DJI Multirotor Forum(A2/WKM) DJI Multirotor Forum(A2/WKM)
Old 09-14-2013, 06:49 PM   #1
LarryLuck
Default Source for DJI AVL58 cables needed
I have an F550 with Zenmuse, Bluetooth, DJI AVL58 TX/RX to a monitor, IOSD, and TM1000 module. I decided to add Fat Shark Attitude goggles to the mix. As most know Fat Shark operates on different frequencies from the AVL. Since the Attitude came with a TX I decided to just add it to the 550. That required splicing into the cable the feeds signal from the IOSD to the AVL TX, and to power. The IOSD and AVL cables are delicate to say the least. Once all together the Fat Shark sort of worked, but the AVL had stopped working. I revisited the cabling and everything seems in order, but I noticed that the 8 pin sub miniature plug on the cable, and the respective connector on the AVL TX seem to have a fried pin (purple #7, that should be signal ground). I'm probably going to need a new TX and definitely need a new cable. A trip to the local electronics store yielded no replacement connector.
Does anyone know of a source for replacement cables for the DJI AVL58 & IOSD?
LarryLuck is offline        Reply With Quote
