Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 09-15-2013, 01:12 PM   #1
Lynn123
Default Cheap 550mm blades
does any one know of any cheap 550 mm flybarless blades thanks
Lynn123 is offline        Reply With Quote
Old 09-21-2013, 01:46 PM   #2
iflywhirlybirds
The cheapest blade I use are the align 550's. 60 dollars for a solid set of rotors. Be very careful when using "cheap" blades, they need to be balanced and if they arent it could cause wonky flight characteristics.
Trex 550e FBL
Beastx
Lifesource LiFe BEC
Spektrum dx8
iflywhirlybirds is offline        Reply With Quote
Old 10-02-2013, 05:03 PM   #3
Dylan Hudock
Mavrikk has their sport series of blades which fly pretty good actually, and auto great! I don't have a 550, but have flown them on my 500.
KBDD Team Pilot Trex 700l-500l-450-150, Gaui X3
Dylan Hudock is offline        Reply With Quote
Old 10-03-2013, 12:04 PM   #4
MotorRotor
These work very well on an FBL set-up.
http://www.heli-world.com/detail.aspx?ID=2254
Phil
MotorRotor is offline        Reply With Quote
Old 10-06-2013, 07:54 PM   #5
flyingquisinart
Default Re: Cheap 550mm blades
Just happened to stumble on this. Heli Direct has fiberglass blades (assuming they still do) for like $18. I have them on my Hurricane 550 and fly well and auto great. Even survived a crash. It's converted to FBL.
Matt
Matt
Pantera P5 50 RNFBL, Blade 130X, mcpx, Gaui X5 FES
flyingquisinart is offline        Reply With Quote
