Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 500X
Blade 500X Blade 500X Helicopters Information and Help
Old 09-20-2013, 05:38 PM   #1
Brian James
Default Blade 500X tail rotor grip recall
Unfortunately, we have a recall on the SOME tail grips of the 500X. There are two styles that have been used in production, we are ONLY recalling ONE of those types. Please read this recall bulletin carefully.
http://www.bladehelis.com/ProdInfo/F...rip_Recall.pdf
Below is a picture showing the two different grips. The one on the RIGHT is the recalled grip, the one on the left is GOOD. The arrows and circles clearly show the differences.
Zeal Rotor Blades
Team Horizon Hobby
Brian James is offline        Reply With Quote
Old 09-20-2013, 07:23 PM   #2
motschill
Unfortunately I do not have the box anymore so I do not have my serial #. So i called horizion to see if they could go off the order # from when I purchased the heli direct from them in the end of January and they had no answer for me. But going off the diagram it doesnt look like my blade grips are the elongated off center ones but its hard to be sure. This is pretty annoying even though its kind of the nature of the hobby. Being that it is a bind-n-fly it is def scary though. Just my 2 cents.
Trex 600e pro beastx Jive 80HV, Goblin 500 quantum 4120 Talon 90, Blade 500x, Trex 450 sport, Blade 300x, Blade 130x
motschill is offline        Reply With Quote
Old 09-20-2013, 07:26 PM   #3
Brian James
It should be pretty obvious if you have the affected grips. If you're still unsure post up a picture, I can tell the difference easily.
Zeal Rotor Blades
Team Horizon Hobby
Old 09-20-2013, 07:34 PM   #4
motschill
Old 09-20-2013, 09:36 PM   #5
Brian James
You're fine. Those are not the recalled tail grips.
Zeal Rotor Blades
Team Horizon Hobby
Old 09-20-2013, 11:34 PM   #6
bladeguy5
Default Re: Blade 500X tail rotor grip recall
Brian are my 2 500x's effected?
Sent from my SCH-I545 using Tapatalk 4
ID:	452295   Click image for larger version
ID:	452296   Click image for larger version
ID:	452297   Click image for larger version
Goblin 700 Competition, Goblin 380, Oxy 3, 180 CFX
bladeguy5 is offline        Reply With Quote
Old 09-21-2013, 08:15 AM   #7
motschill
Thank you Brian James.
Old 09-21-2013, 10:40 AM   #8
Brian James
Nope. You're fine.
Zeal Rotor Blades
Team Horizon Hobby
Old 09-21-2013, 02:32 PM   #9
hoverfun
Is the serial number on the manual? Is this number A212122000720010264 OK?
hoverfun is offline        Reply With Quote
Old 09-21-2013, 04:21 PM   #10
Brian James
No, only on the box.
Zeal Rotor Blades
Team Horizon Hobby
Old 09-21-2013, 09:45 PM   #11
shahram72
I assume this does not affect the 500 3D? I thought they shared these parts,
I swear these clones are supposed to fly. I saw it on youtube!
shahram72 is offline        Reply With Quote
Old 09-21-2013, 10:39 PM   #12
Brian James
Nope. The 500 3d was produced before the 500x. No problems with the 3d.
Zeal Rotor Blades
Team Horizon Hobby
Old 09-21-2013, 11:33 PM   #13
Iskareot
Now, would this cause the bad vibes and tail issues we have in the group of the first run of these? I have to ask this.
Goblin 380/Compass Exo/Mikado Logo 700/Vbar control/Neo/RCHN #612 IRCHA#5289
Iskareot is offline        Reply With Quote
Old 09-22-2013, 02:57 AM   #14
crashcopterman
Doubt that was primary reason. I have a second design, 'centered bolt' grip, and out of the box mine growled and buzzed like crazy. Only needed the infamous tail fin bolt adjustment.
Nano CPX || 130x || 450 3D converted to 450X || 360CFX || 550X || ALeeS Rush 750 Evolution 'My flight style, determines my crash style"
crashcopterman is offline        Reply With Quote
Old 09-22-2013, 09:00 AM   #15
Brian James
Nope. The first run is actually the grips that are NOT recalled.
Zeal Rotor Blades
Team Horizon Hobby
Old 09-22-2013, 11:01 AM   #16
hoverfun
Default box #
This was the number on my box.
Old 09-22-2013, 02:33 PM   #17
Brian James
Please look at the pdf, it should be very clear if the grips are the recalled ones.
Zeal Rotor Blades
Team Horizon Hobby
Old 09-23-2013, 12:31 AM   #18
Iskareot
Yep I looked it was not them. Although I still have my vibes and so on. I may just take it apart and attempt adjustment. I don't even fly it much due to this now.
Old 09-25-2013, 02:04 AM   #19
FlightAddict
Default speechless...
Mine just failed, right before lift off on the second flight attempt. I heard a pop and immediately spooled down. Its good the heli was still on the ground and about to do a piro right after the pop.
i immediately checked the heli and one of the grips was gone but the bearings, washers, and screw was still intact on the hub. Closer inspection showed the flange on the grip was sheared off. I emailed HH and awaiting response at the moment.
Other anomalies observed after the incident were a loose drive belt and a misaligned tail assembly.
Note that the heli was thoroughly pre-flighted before each flight attempt and post-flighted after the first flight. First flight was familiarization and orientation hover only.
I came across this thread just now checking for others who may have had the same incident.
ID:	453252   Click image for larger version
ID:	453253   Click image for larger version
FlightAddict is offline        Reply With Quote
Old 09-25-2013, 02:24 AM   #20
FlightAddict
looks like mine are the elongated ones.
