Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 350QX
350QX Blade 350QX Multirotor Information and Help
Old 09-21-2013, 05:21 AM   #1
kaylanova
Default Binding the 350QX
Although I got the RTF version I had to rebind and did so in the 'normal' bind process and everything seems fine. I'm just flying in smart mode and the quad is behaving as it should.
I notice however that there are two other methods of binding, with and without gps enabled. Should I have been doing either of these methods or am I OK with doing just the normal bind.
kaylanova is offline        Reply With Quote
Old 09-21-2013, 11:19 AM   #2
755 robert
If you are getting the gps lock then you are fine.The only time you would use the other methods is if you want to disable the gps and if you want to enable the gps..
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class().Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even.
.Who is John Galt?
755 robert is offline        Reply With Quote
