Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > nano QX
nano QX Blade nano QX Information and Help
Old 09-22-2013, 07:46 PM   #1
Squenards
Default Nano QX Setup on Dx6i
Does anyone know how to set "agility mode" on the Dx6i? Instructions are super vague. It doesn't appear to be the usual flight mode toggle.
Squenards is offline        Reply With Quote
Old 09-22-2013, 10:28 PM   #2
SkyHawk52
Give this a try "Nano QX dx6i "Heli" Profile"! Works great!
http://www.helifreak.com/showthread.php?t=543747
Blade 230 S - Blade mCPX V2 - Blade Nano CP X - E-Flite P-51D BL - E-Flite P-47 BL - HobbyZone Sport Cub S2 - DX6 - RF 7.5
NO, you can't my helicopters!
SkyHawk52 is offline        Reply With Quote
Old 09-23-2013, 09:52 AM   #3
jcmo
If you are set up using the manual's instructions, you would flick the "trainer" or bind switch. When the switch returns to its resting position, the Nano should change mode.
FP - Blade mCX2/mSR {x2}/Nano QX{x2}/120SR - Syma s107g - Xieda 9998{x2}
CP - Blade Nano CPx/mCPx(v2+BL {x2})/CP Pro 2(Scale Build in Progress)/300x/300xSS(Benched)
TX - Spektrum DX6i/DX8
jcmo is offline        Reply With Quote
Old 09-27-2013, 11:23 AM   #4
Squenards
Well, thank you very much for your attempts, and I hate to say it but you all were wrong. Actually, I'm a little glad to say it because I tried all of those things before I started this thread.
So how is it done? Fairly simply:
Set the QX up as a plane, not a helicopter.
Then, in the FLAPS menu, set flaps to Normal and down 20%. Now it's set and ready.
To ACTIVATE agility mode, toggle the flaps switch to 1 AND THEN BACK to 0. Repeat to turn it off. It takes two actions to toggle.
Works perfectly!
Old 09-27-2013, 03:07 PM   #5
jcmo
I knew the manual's instructions say to set it up as an ACRO model, which is normally a plane, but I was confused about the switch because I think I've read too many threads here.
It sticks out in my mind that because it's a "toggling" action, a momentary switch like the trainer switch or button would be more ideal for that action. Some have suggested modifying the stock transmitter settings in that small way, and I agreed with it so much I must have integrated it into my basic understanding of the defaults.
Thanks for setting us straight! I don't want to steer anyone wrong.
Old 09-27-2013, 04:47 PM   #6
Squenards
I hear ya! And then there's the confusion caused by too many heli's... on and on! I appreciate the help regardless!
Old 09-29-2013, 11:48 AM   #7
youngb87
Actually, just to state, The "HELI" mode thread is not wrong. It works great and many prefer to use it over the acro setup.
What goes up, must come down..... We hope!
Blade 500 3D, Blade 450 converted to X, Blade mCPx v2, Blade Nano Qx
youngb87 is offline        Reply With Quote
Old 09-30-2013, 01:18 PM   #8
jcmo
Yep, I use the same settings in the dx6i thread on my dx8, except I also assign the position '0' pitch curve settings to position '2' on my F.Mode switch, so the change from stability to agility mode is just quick flick of the switch past position 1 from 0 to 2.
I was glad this question came up with some follow-up from Squenards, because I know the question of how to change to agility and back using the stock Tx settings has been asked around here before, and in trying to be helpful I've answered it incorrectly, sounding quite sure of myself
Old 09-30-2013, 01:48 PM   #9
youngb87
You were pretty close. But like the slightly arrogent one said, in ACRO mode, its a quick flip up and down (or vise versa, I dont have in front of me) with the Gear/Flaps toggle, where in HELI mode, you use the flight mode toggle in the same manner. HELI mode really give you more options. And it really helps you out if you fly actual helis!
Old 03-14-2015, 04:33 AM   #10
freeman59
Default problem srability nano QX
Hello : I am a Italian fly beginner and 'trying to learn to fly with the nano QX with a DX6i radio but I have some difficulty': every time I turn on the radio and QX nano behaves and fly in a different way: sometimes uncontrollable sometimes less, however almost never can hold in a stable hovering him down: moves to the right or left forward or back and for me 'not' easy to learn and fly it well : I can give some advice and tell me' and that 'the set up for the DX6i to do to become more' stable and more 'easy to do fly? I don't understand where is better setting acro or heli....Many thanks to all and "ciao".
freeman59 is offline        Reply With Quote
Old 03-14-2015, 09:40 AM   #11
GoatRider
You have to make sure it's on a level surface right after you put the battery in it. Whatever orientation it's in when it initializes is what it considers "level". If it's properly level, then you won't get any drift. If it's tilted to the left, then it will drift to the left.
- Benton Jackson, Maple Grove MN
Roswell Flyer (retired), Concept EP (retired), Eco 8 (retired), WLToys V929 & V202, Nano CPx, Nano CPx mild BL, Nano QX, mCX2, 130x
GoatRider is offline        Reply With Quote
Old 03-14-2015, 09:53 AM   #12
freeman59
Thanks: yes.. it is in a perfect surface...: but please I need a best set up for the dx6i...: I see some set up on the web ...but do not know 'what is the best to make the QX fly stably...
