Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 350QX
350QX Blade 350QX Multirotor Information and Help
Old 09-29-2013, 03:29 AM   #1
slashmarx
Unhappy Blade 350 QX not binding
So I bit the bullet and bought the 350. This is my first experience with RC flight. I have spent all night trying to bind the controller the the 350 without any success. I hit up a dozen youtube videos and websites, still no success. This IS the model that comes with the controller and is SUPPOSED to be bound by the factory...
I am following all of the instructions and have attempted variations of the following (including trimmer adjustments, hi vs. lo, channels, and throttle settings) :
- I connect the battery
- Power the 350 on
- pull trainer switch while turning remote on (I have also tried different combos holding left knob to rt, left, etc)
the 350 continues to flash blue.
I know that I am doing something wrong and would LOVE to know what!
Thank you so much for your hep!
Chris
slashmarx is offline        Reply With Quote
Old 09-29-2013, 09:33 PM   #2
ArchmageAU
Blade QX is not bound at the factory.
Follow bind instructions in the manual (requires certain stick positions on the transmitter when binding). Not currently on a computer where I can cut and paste the manual page.
Talk to local hobby shop or Horizon hobby if still having problems.
ArchmageAU is offline        Reply With Quote
Old 09-29-2013, 09:38 PM   #3
slashmarx
After a call to tech support, we found out that the batteries were bad.
Flying like a champ. The only issue I have now is finding my lost black gopro mount gasket... Has anyone had to replace theirs yet?
Thanks again!
Chris
Old 09-29-2013, 09:47 PM   #4
pixeltim
Thanks again!
Chris
Do you mean those cute round kinda spongy things that I just lost 3 of today?....
My aerial photos are at pixeltim.com
Phantom 2 Vision and assorted other egg-beaters.
pixeltim is offline        Reply With Quote
Old 11-28-2013, 08:56 PM   #5
Zenthor
I too could not arm my 350 QX...after much troubleshooting, here is what I found out:
My Dx5e is slightly over trimmed on the throttle. I found this out during calibration on Pheonix 4 simulator where I saw that after it was 'calibrated', it showed the throttle 7 clicks too high.
Nothing I tried could compensate for this and I could not stat it. I had an old DX4 which started it perfectly and I went to local hobby store and there older version DX5e also worked fine.
I see via Google that many people have a problem starting the QX 350 and the most common suggestion is to bump up the throttle 2-3 clicks and then retry...this and everything else failed with my DX5e.
I do not think Spectrum will see a problem as I would guess they would say that is what trims are for. My temp solution is to use my DX4 which means I only have 2 modes. I have ordered a DX6i....but worry that others out there have problems with it too.
So, to sum up...this quad seems to be VERY picky about the throttle being absolutely exact...I do not know if it can be fixed with a firmware patch. During one of my calls to Horizon Hobby Support, when I told them about the numerous post on Google about this problem he sounded nearly hostile and insisted I go step by step with his troubleshooting (including counting clicks on trims)...and as I stated none of it worked. Until enough people complain, Horizon does not seem to be in a hurry to acknowledge the problem.
Got to say though...once I got it in the air with my DX4...it is a very fun helicopter.
Zenthor is offline        Reply With Quote
Old 12-01-2013, 02:46 PM   #6
Newtonian
Default I am having the very same problem with the RTF
After several successful flights the quad just won't fire up tthose props.
I havnt tried adjusting the trim up or down yet. I was not advised of this.
I will try tomorrow but I wasted an hour on Friday that I cannot afford!
I need reliability!
Newtonian is offline        Reply With Quote
