Old 10-13-2013, 07:18 PM   #1
squeely531
Default Dx9 problems?
Has anybody had problems with the dx9? I have put 4 in since I started using the dx9 with an ikon and 2 remote dsmx sats. Pretty much the same on all 4 crashes with 3 different helis. Cyclic and tail stop responding and throttle hold works? I called horizon and they said there wasn't a problem that they knew of and asked me what I wanted to do about it? Thanks for any input.
squeely531 is offline        Reply With Quote
Old 10-14-2013, 07:34 PM   #2
taterb
I don't have a lot of flights on mine yet, but I haven't had any problems yet (planes or heli's). I do use VBar as my FBL unit though.
taterb is offline        Reply With Quote
Old 10-14-2013, 09:49 PM   #3
cajkat1073
No problem on 4 different 7200bx.
Alees Rush 700 x3, Alees Rush 750, 180cfx, 250 quad racers, OMG servos, Force batteries
cajkat1073 is offline        Reply With Quote
Old 10-14-2013, 09:54 PM   #4
atkin
hope this isn't the same as the dx18 thing since it is a similar code base.
DX8, Trex 700 dfc, Trex 550 dfc, Oxy3, Rifle 1M (plank!) PL8, PL6
atkin is offline        Reply With Quote
Old 10-15-2013, 06:00 AM   #5
Rusty2
I have an ikon on my 500 550 and 700 with a load of flights and no issues at all.
I'm down like 4 flat tires...... T-Rex 500 esp ikon.......T-Rex 550 pro dfc ikon...... ........T-Rex 700 pro dfc ikon
Rusty2 is offline        Reply With Quote
Old 10-15-2013, 09:06 AM   #6
squeely531
Are your settings with the ikon at dsmx 22ms or 11ms? Thanks for the reply
Old 10-15-2013, 09:13 AM   #7
Dipweed
Question Dx18 Dx9
Did a check on Dx18 but could not find the Dx18 post problem
so
What was the problem with Dx18 and what was the fix
Align&HK450 L/470L/150 DFC/Blade stuff
DJI/AR Drone
Dipweed is offline        Reply With Quote
Old 10-15-2013, 10:10 AM   #8
atkin
Sorry, I dont own a dx18 (or know the fix), but here is one of the threads:
http://www.helifreak.com/showthread.php?t=547445
edit: oh wait, i read the end of that thread, people look happy with the update that was released a month or two ago. I'm sure the dx9 has the same update built in since it was released. False alarm I hope!
so
Old 10-16-2013, 08:26 PM   #9
squeely531
Default Maybe my dsmx sat
Flew my blade 450 with everything the same except using my dx8 and still had loss of response mid flight. I am beginning to think it is a rx issue. I will post when I figure it out.
Old 10-18-2013, 05:45 AM   #10
Rusty2
Both 22ms and 11ms ,,,,,,,, I only have dsmx on my 700
Old 10-20-2013, 11:23 AM   #11
LoveToFly1
Tons of flights on all my birds and nothing funny here.
Only issue I have seen is throttle trim didn't work in my first setup of my gasser, had to creat a new model and start over, but it works now and I'm happy.
LoveToFly1 is offline        Reply With Quote
Old 10-24-2013, 04:26 AM   #12
helicraze
Can someone tell me how to stop the trim noise on the back, mine when centered go crazy and wont shut up!
helicraze is offline        Reply With Quote
Old 10-27-2013, 09:05 AM   #13
nmdesertracer
turn the trim sound off?
Slow & Steady!
nmdesertracer is online now        Reply With Quote
Old 10-27-2013, 09:32 PM   #14
dexterous
I have lots and lots of flights (all on AR7200s) with zero issues.
DX9, 600x, 500x, 450x, 300cfx, and a nano CP Xs or two (plus the stuff I have hidden from my wife...)
dexterous is offline        Reply With Quote
Old 01-31-2014, 10:10 PM   #15
jimthetooth
Default dx9-dx18
had the dx18 had many issues causing crashes, traded for 2 dx9s one is working so far but only 2 months, the other locked up,had to remove the battery then it seemed to work . then 4 days later the screen went blank,sent it in, asked for a replacement, they refused and sent it back fixed. used it for 10 minutes on the trainer and the screen went dead again. had to send it back again. sucks to have to have 2 radios to have a working one. never had a problem with the dx8s I had. just got tired of buying new antennas. futaba looking better all the time
jimthetooth is offline        Reply With Quote
Old 02-01-2014, 04:15 AM   #16
bdcpv
i have a dx9 with blank screen problem (i am reading… and some users had this trouble using radio with simulators usb interface)
regarding crashes… at today i have nothing to tell with more than 10 heli models with various fbl and receiver systems (3gx,brain,beastx,tarot, ar7200, spektrum receivers, dsmx/2 sats, orange receiver,etc.)
i did some hundreds of flights.
bdcpv is offline        Reply With Quote
Old 02-01-2014, 08:46 AM   #17
Smith T
Sounds like signal drop usually due to drop in voltage especially when using SATs only. Tons of threads on it if every thing checks out mechanically an external BEC usually corrects the issue.
With my pilot skills I have no choice but to become a good mechanic.
Smith T is offline        Reply With Quote
Old 02-01-2014, 03:08 PM   #18
aerocal
Can you explain exactly how your DX18 "issues" caused many crashes? Ive had jointed antennas ever since the DX7(original) I used many years ago now.Never a broken antenna. I can admit they are somewhat fragile but breaking then repeatedly?
Im kind of guessing theres disparity in the definition of due care and diligence here.
Even an egg doesnt break itself.
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote
Old 03-26-2014, 03:22 PM   #19
alexmanov
Default Re: Dx9 problems?
Same thing to me just happend.I turn it on change the model to "sim",turn it of,place the jack on the back and the screen went dead.I am sending it tomorrow and the first thing when it cames back it will be to get rid of this peace of shit.
Sent from my GT-N7100 using Tapatalk
alexmanov is offline        Reply With Quote
Old 03-26-2014, 04:38 PM   #20
calbest
I have 3 BX'S and an Ikon that are setup on my DX9. The only problem I have had is on 1 of my 450X with BX I am getting about 10-12 frame losses.
Other then that it is a great radio.
calbest is offline        Reply With Quote
