Old 10-29-2013, 05:17 AM   #1
#1RCHelifan
Default Compass Tracx FBL vs BD-3SX
Just got me a new Compass 7HV v2 and was planning on getting the BD-3SX as I'm interested in its Captain Rescue bailout function However, I just ran across the new Compass Tracx FBL system and noticed it too had a self leveling feature that rights itself up in the event you need to bail out. Before I shell out $500 I wanted to know if anyone was using the Comapass Tracx system and how does it compare to the BD-3SX bail out feature. is the BD-3SX still the better system?
#1RCHelifan is offline        Reply With Quote
Old 10-29-2013, 05:31 AM   #2
DannyvG
FYI, the compass tracx is the same unit as the MSH Brain (original) and Ikon (rebranded) so include those in your search for the answer.
The common remark with respect to the self level in the brain is that it is more vibration sensitive then the 3SX.
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote
Old 10-29-2013, 06:47 AM   #3
rocketronnie2008
This should be good to find out, I have the BD3sx in my goblin 700 and I'm loving it
rocketronnie2008 is offline        Reply With Quote
Old 10-29-2013, 01:27 PM   #4
im4711
I use different systems and when it comes to serious bailout function - the BD3SX still is the market leader. Others can self level - just bail out in any situation (except already hitting the ground) worked fine for me so far only with BD3SX. A few folks at the field bit the bullet and got themselves a BD3SX and actually ended up using it a few times. Each crash would have paid for the price difference you pay.
In addition the system itself is an awesome FBL system with great flight characteristics. I an tune them as well asI do my vbar or ikon systems. I guess there is a reason why the price did not yet come down. There is no other system on the market with the same feature (not talking leveling - talking bailout).
im4711 is offline        Reply With Quote
Old 10-29-2013, 01:31 PM   #5
rhodesengr
also, only the 3SX adds pitch during the rescue to get away from the ground. Vibrations are of little impact. I have it working on two gassers and a 550 electric.
This is your brain on helicopters!
Trex 700L, Trex 700N DFC HB gasser,Trex 700N V2 HB gasser, Trex 550E FBL all with BD3SX
rhodesengr is online now        Reply With Quote
Old 10-29-2013, 03:55 PM   #6
tracernz
The Brain/iKON/TracX self level can work quite well if you isolate it from vibrations but it's only a self level. The 3SX will level either inverted or upright and apply collective as required to go towards the sky and it's never once failed in my testing.
| Jeti DS-16 | Compass 7HV / HC3SX | SAB Goblin 500 / iKON | Align Trex 500e DFC / AR7200BX | Tarot 450 Pro DFC / iKON |
tracernz is offline        Reply With Quote
Old 10-29-2013, 05:01 PM   #7
rhodesengr
I've been told that the newest Skookum model with GPS can act similar to the 3SX but I think its even more expensive.
Old 10-29-2013, 07:37 PM   #8
Cailid
With the gps it is more expensive, but it has more features.
Dogs come when called. Cats take a message and get back to you later.
Cailid is offline        Reply With Quote
Old 10-29-2013, 07:43 PM   #9
fastflyer20
Not sure the new SK will work with the vibes on a gasser. The original 720 SL did not work.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is online now        Reply With Quote
Old 10-29-2013, 09:40 PM   #10
rhodesengr
just trying to be fair. I said on some other thread that the 3SX is the only FBL that adds pitch and I was corrected that the 720-GPS does it of course at near twice the cost.
Old 10-29-2013, 11:50 PM   #11
Bubbasanjohn
For me, I saved 300 dollars and got an ikon. I just add collective. I have found in my case adding pitch is not the problem but level orientation is.
Bubba
Goblin 700
Jeti DS-16
Bubbasanjohn is offline        Reply With Quote
Old 10-30-2013, 05:38 PM   #12
desertstalker
Unlikely, though some did manage to get low enough vibration for the old one to work.
The HC3SX will probably work on a gasser though, since it has no accelerometers to get confused.
-DX8
Old 10-30-2013, 08:20 PM   #13
fastflyer20
There are many 3SX's running on gassers, not only does the SL work, but they fly great too.
Tom
TRM Power
