Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > 350QX
350QX Blade 350QX Multirotor Information and Help
Old 11-15-2013, 08:20 PM   #1
megraham
Default Binding the DX6i with the 350 QX
Followed the videos and setup the DX6i just as the video showed. Went to bind and had to try a few times and finally it worked but couldn't get the motors to start. Also had a continuous beep in smart mode but when I changed it to stability the beeping stopped. It would also stop in smart mode when I raised or lowered the trim of the right stick. Once I adjusted the trim, I tried starting the motors again but nothing happened.
Any suggestions or tips to get this thing bound?
megraham is offline        Reply With Quote
Old 11-15-2013, 08:35 PM   #2
755 robert
Try trimming the throttle channel up a few clicks at a time till you get an arming tone...
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class().Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even.
.Who is John Galt?
755 robert is offline        Reply With Quote
Old 11-15-2013, 08:42 PM   #3
megraham
Tried increasing it 1 click at a time but this didn't work in my case.
Old 11-15-2013, 08:56 PM   #4
hotrodhawk
I had this problem when I had DR high rate 100% assigned to the (1) position on switches. It needs to be on the (0) side of each switch and 70% on the (1) side on a dx6. Wish they would of called that out clearly in set up config.
Have alie and elv dr in the (0) position to arm motors with the throttle trim 3 clicks above center.
hotrodhawk is offline        Reply With Quote
Old 11-16-2013, 01:37 PM   #5
PaPaGrizz
Instead of messing with the throttle trim on my Dx6i, I went into the program menu and selected "sub trim" > throttle, and set it to =10% if that doesn't work you can keep adjusting the percentage up..
Hope that helps.
Blade cx, 2 x 107g's, wl 202, Frankenquad, wl 212, wl 222, syma x1, blade 350qx Dx6i, rc logger eye one xtreme, Nano Qx, 200 srx, Mcx2 for indoor grins
The only easy day was yesterday!
PaPaGrizz is offline        Reply With Quote
