Old 11-27-2013, 12:47 PM   #1
Tek18x
Default trex 450 pro v2 DFC to trex 450L Dominator
Hey guys,
I'm going to transfer my 450 pro v2 DFC to the new 450L
These are the parts i will order
Do I need any other parts? I planned to not get the frame just yet, If i order the frame do I need anything else aside from the Frame and bearing blocks?
scorpion hk-2221-6 is the motor I currently have, should I get the new 460 MX that comes with the 450L?
Didn't plan to run 6s just yet, will continue to run 3s until I upgrade the motor.
Just getting my thoughts down to see if anyone has any comments
Gaui X3
Synergy E5
Dx8
Tek18x is offline        Reply With Quote
Old 11-27-2013, 02:17 PM   #2
Tek18x
Beacuse of the weight of the 450 360MM blades, i added these
My questions are:
Will I be okay with the v2 frame?
Can the servos handle it?
Should i get the 460MX 1800KV motor?
Gaui X3
Synergy E5
Dx8
Old 11-27-2013, 07:59 PM   #3
genuine
Wink did
My questions are:
Get the L MTR mount also, boom block,anti rotation bracket,everything else should be fine.
genuine is offline        Reply With Quote
Old 11-27-2013, 08:33 PM   #4
Tek18x
I don't need those if I use the stock frame I thought?
Gaui X3
Synergy E5
Dx8
Old 11-28-2013, 05:17 AM   #5
genuine
i think the mtr mount is a bit differnt, i didnt use my old pro mount,just went ahead an got the L,an the boom block,cause the boom block does have differnt mounting hardware cause it actually sets in the plastic inserts that are on the frame. i did the complete swap also just orderd ever thing new,skiddz stilll the same.
Old 11-28-2013, 05:19 AM   #6
genuine
Old 11-29-2013, 08:56 PM   #7
Yfbb
New motor mount from the 450l won't fit. It's too wide. The stock one will work fine.
Yfbb is online now        Reply With Quote
Old 11-30-2013, 04:53 AM   #8
genuine
Thumbs up
Humm didn't get what heli you are converting over too? Thought you where takeing the pro an converting over to the 450L
Old 11-30-2013, 04:21 PM   #9
CrashNburn420
Look for the thread in this forum about the guy who did this same strech. He had issues with the main blades and tail blades colliding while flying. Its called something like "dont do this with your 450dfc"
CrashNburn420 is online now        Reply With Quote
Old 12-02-2013, 01:19 PM   #10
RedJoE
All you need is the main blades, torque tube/boom tube combo and servo linkage rod. Everything else is unnecessary.
Got 30+ flights on mine with the above changes, flys great with the stretch.
RedJoE is offline        Reply With Quote
Old 01-02-2014, 01:34 PM   #11
tomd27858
What speed control are you running with the 450MX on 3 cells? I would imagine the current load would be somewhat higher running the larger tail and main blades.
I am interested in stretching an old 450 pro myself but hate to sink a lot of dollars into a 450.
Team HeliDirect
Flying Align - Powered by Pulse
tomd27858 is offline        Reply With Quote
Old 01-02-2014, 01:40 PM   #12
xrayray
yeah the Align 360's are like a half inch longer than all the other "350mm" blades out there just so you know on a PRO stretch it may hit the tail blades especially if you're DFC (shorter main shaft) and if you run the longer tail blades.
I am very interested to know how the stretch will affect the esc/motor and bogging on 3s. How low does the collective pitch have to be to prevent bog? What headspeed on 3s?
Team FlybarLESS
Trex 550e FL
Trex 450 pro DFC
xrayray is offline        Reply With Quote
Old 01-02-2014, 04:17 PM   #13
Yfbb
The thing is that the 450l runs the exact same drive train as the 450 pro with almost all identical parts. The head is the same, the tail is the same, the booms are the same if you stretch, and the gears and boom blocks are the same. It is very bizarre that blades that work on the 450l don't work on a stretched pro. Even so, if you look at the images on the thread on this issue, the blades only overlap 3-4mm, so if you do have clearance issues, you can just slide the boom out of the boom block a little bit and everything should be perfect.
Old 01-03-2014, 11:44 AM   #14
tomd27858
Interesting.
Has anyone stretched their 450 pro on 3 cells? If so, what esc did you use and how was the performance?
Team HeliDirect
Old 01-03-2014, 12:30 PM   #15
jetblue2135
Don't use the Align 360's if you plan on doing the stretch this way. On the Pro they will collide with the tail blades, even 61mm blades. The 450L its not a problem because it is a further distance.
I am using RJX and Lynx 350's on my DFC Pro that I stretched just like you are talking about. Here is my stretched DFC pro, since the pic I have changed the head block out to the new 450L one. I figure flying it hard on 6S it's better to have 3 bolts securing it vs. one Jesus bolt. Having that bolt sheer off just once was enough convincing for me! Also I have the new beefier feathering shaft.
EDIT: I originally posted a pic of the my DFC Pro before I stretched it out. Here is a pic of what it looks like now. I am using the 460MX on 6S in it and also swapping out between the scorpion 2520-1880KV...which is a monster. The 450 Pro stretched is lighter than my stock 450L.
ID:	476263   Click image for larger version
Smiling 's my favorite
jetblue2135 is offline        Reply With Quote
Old 01-03-2014, 12:44 PM   #16
Luigi_tuga
If your DFC head isn't upgraded yet, the new beefy FS kit is a must, it would be very sad to see one of your main blades let go
Logo 480, Warp 360 , Sport 360
T500 AP
PZ StrykerQ DX8
Luigi_tuga is offline        Reply With Quote
Old 01-03-2014, 01:41 PM   #17
Yfbb
Even if the 450l does have more clearance, it puzzles me because I can't figure out which part provides it. The drive trains look identical to me.
Old 01-03-2014, 05:28 PM   #18
xrayray
It could be the way the frames are drilled.
Team FlybarLESS
Trex 550e FL
Trex 450 pro DFC
Old 01-03-2014, 05:36 PM   #19
Yfbb
The frames cannot affect this. If they are drilled differently, then the gears in the boom block won't mesh with the autorotation gear. The only thing about frames I can think of is if the main shaft is angled foreward, but that seems kind of stupid.
Old 01-03-2014, 05:44 PM   #20
xrayray
hmm yeah now I get why this is confusing. Maybe there's a difference in the old pro tail case to the new L tail case that looks like the 500/550 tail case.
Team FlybarLESS
Trex 550e FL
Trex 450 pro DFC
