Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Old 05-22-2005, 06:12 PM   #1
Tristan Buhler
Default Tree Hugging and Swimming
After flying a heli and plane can get boring, expecially if its a trainer, avistar. So to get the normal heli rush I was seeing how low and how fast I could get inverted. Well I was making inverted circuits and ended up clipping a tree. Made a thumb but it was still flying. I pulled out of it and was on down wind when my engine cut(out of fuel to) so i turned back up but was short of the runway anyway. I set it down in the bushes/ grass. Next thing I see is a splash. I could not believe it. 3 bad things in a row. Luckly the tree did not damage it to bad and mostly the landing gear only was in the water. The monokote was ripped and the leading edge had a little dent but the motor started up again and it has flown some more.
-Tristan Buhler
Tristan Buhler is offline        Reply With Quote
Old 06-11-2006, 06:46 PM   #2
Rick Rotorhead
Wow, thats real unlucky, but could have been worse. Lightning strike before you could retrieve it or a small meteor rock zeroing in hee hee. Yeah its strange how events conspire against you at times.
450SE Silver - Power: Neu1107-2Y + 10t pinion ESC: Jazz 40-6-18 Governed. - Batts: 4s, FP 2100 Evolites. Pitch +/- 12* (TC63 PC 0,25,50,75,100), cyclic 6* HS2900
HS65Mg x3 + GY401 + S9650 tail.... Rx: AR6200 - Tx: FF9Super(T9CP) +Spektrum Module
Crash count = 13 for 179. Trex time aloft = 22:42
Rick Rotorhead is offline        Reply With Quote
