Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 05-24-2005, 03:50 AM   #1
Xtreme*76
Default ATV VERSUS AFR
Do you know if the value of ATV
(for example 95% for rudder)
is the same of AFR?
Thank you very much
Regards
Giuseppe
Xtreme*76 is offline        Reply With Quote
Old 05-24-2005, 08:24 AM   #2
Beast
it is the same but remember for futaba gyro, the rudder atv or afr controls the piro speed not the end point.
Beresford
Beast is offline        Reply With Quote
Old 05-24-2005, 09:24 AM   #3
Xtreme*76
Dear Beast
thank you
everything is clear
You mean that if I want to increase or reduce the
rudder speed (and use different speeds on different conditions)
I can use only the AFR (single) on the 14mz
For the limit I have to set them directly on the gyro ....
Hope I'm correct
Regards
Giuseppe
Old 05-24-2005, 10:00 AM   #4
DavidH
Yes AFR will control the pirouette speed in different flight conditions.
For travel adjustment that needs to be done on the GY 601 menu.
I prefer to use the AFR to control piro speed instead of the ATV. I leave the ATV defaulted to 100%
David
DavidH is offline        Reply With Quote
Old 05-24-2005, 10:45 AM   #5
Xtreme*76
Sorry DavidH
but did you read my post about lost of tail?
Thank you very much
Regards
Giuseppe
Old 05-24-2005, 11:02 AM   #6
Bklyn
David...
Why AFR over ATV?
John
IRCHA 777
Bklyn is offline        Reply With Quote
Old 05-24-2005, 11:11 AM   #7
DavidH
With the AFR the rate is handled within a function. So if anything is mixed with that channel it handles it also. ATV just controls the one channel.
AFR= Adjustable Function Rate
ATV = Adjustable Travel Volume
For example if you adjust ATV one side 80% and the other side 100%. Then the neutral is offset some.
With AFR if the ends are different, the neutral stays the same.
David
Old 05-24-2005, 11:19 AM   #8
Bklyn
Thanks, makes sense to me now
John
IRCHA 777
Old 05-24-2005, 11:22 AM   #9
NolanManley
FINALLY !!!! David put Futaba's ATV/AFR in plain english. Southern english at least.
Stratus & Protos.
Magnum Fuel, KBDD intl Products
NolanManley is offline        Reply With Quote
Old 06-05-2005, 11:52 PM   #10
cforcht
I agree its about time someone explained the meaning of ATV and AFR it makes alot more sense now why you use the AFR over the ATV.
recovering heliholic
cforcht is offline        Reply With Quote
Old 06-10-2005, 08:32 AM   #11
modtron
Default ATV - AFR
On the 14MZ you should find that the ATV function is common in ALL conditions. Whereas, with the AFR, this is adjustable for different settings for each condition being used.
Therefore the ATV can be used to set the overall control stroke required and the AFR can be used to adjust individual stroke in each condition.
The neutral moving, also happened with the 9ZAP. If you set different values for A & B in the ATV ( 40% & 100% ) you will notice that the centre or neutral will be be dagged away from its normal setting. If the same is done using the AFR, the centre / neutral will remain in the same place.
modtron is offline        Reply With Quote
Old 09-12-2005, 03:12 PM   #12
lfalsetto
Finally got around to reading this post and maybe this will answer my question. I was using ATV to adjust my travel endpoint or Pyro. When I switch to low rates or to Idle up the rudder servo would operate in slow motion. Could this be my problem?
lfalsetto is offline        Reply With Quote
