Old 01-24-2008, 04:19 PM   #1
the_aviator
Default Moth the T-Rex
Nothing radical, I'm thinking about 2-4 inch shorter tail boom and main blades. Can it be done? Has anyone tried to make their T-Rex a little closer to a 300 size?
the_aviator is offline        Reply With Quote
Old 01-24-2008, 05:21 PM   #2
Pinecone
The original 450X had a shorter boom and only ran 315mm blades.
The problem is, as you reduce the blade length, you significantly decrease the rotor disk size, which increases the disk loading as you don't loose much weight by shortening the boom adn blades.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 01-24-2008, 05:26 PM   #3
markb
I've actually thought about doing the opposite for the endurance competition, and maybe a scale application. A stretch Rex. With longer blades, maybe flat bottom, and extended tail boom.
Mark
Logo 600se, Scorpion 5020-450, mini-V, Jive 80HV
Trex 600 ESP FBL, Scorpion 4025-740, cgy750, CC85HV
Trex 450 Vx FBL, Scorpion 2221-10, RJX head, mini-V, Ice 50
markb is offline        Reply With Quote
Old 01-24-2008, 08:41 PM   #4
the_aviator
Hmm OK, maybe I'll just start with a 300 size frame.. do you know a good 300 size heli that can take a T-Rex SE head without too much hassle?
