Old 01-26-2008, 07:28 PM   #1
autopilot
Default grounding the boom
I have had no problems with my 500, but I am considering soldering a small wire from the boom to the frame to reduce static on the tail so I dont have any brownout issues in the future. If i do this are there any possible disadvantages, and is this the correct way to do it.
Thanks in advance.
T-rex 450 SA
DX7 radio
GY401
T-rex 500
autopilot is offline        Reply With Quote
Old 01-26-2008, 08:30 PM   #2
duceduc
You don't need to ground the boom just the esc to the motor mount says trextuning.
http://www.trextuning.com/blog/?p=230#more-230
duceduc is offline        Reply With Quote
Old 01-26-2008, 10:05 PM   #3
hozer
Pcm?
hozer is offline        Reply With Quote
Old 01-26-2008, 10:12 PM   #4
autopilot
Dx7
T-rex 450 SA
DX7 radio
GY401
T-rex 500
Old 01-26-2008, 10:14 PM   #5
autopilot
Also I am running a cc phoenix 60 with a seperate bec so I don't think I will have the problem that the stock Align esc has.
T-rex 450 SA
DX7 radio
GY401
T-rex 500
Old 01-27-2008, 02:27 AM   #6
drzoidberg
I ground the booms on my helis. I followed a tip in RC Heli to attach a small wire to the boom and then to the chassis. Basically a peace of mind but makes sense to me.
T-Rex 250 - T-Rex 450SE - T-Rex 500CF - T-Rex 600CF - T-Rex 600N - Raptor 50SE
All flown with a Spektrum DX7, Hitec servos, Futuba/JR/Logitech gyros, Radix blades, Scorpion motors and Flight Power lipos.
drzoidberg is offline        Reply With Quote
Old 01-27-2008, 09:07 AM   #7
Pinecone
What you really need to do is to connect the belt pulleys electrically. The boom and frame can be used to do this, but the plastic tail case, means an electrical connection is needed between the tail pulley and the boom.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 01-27-2008, 09:28 AM   #8
Socal500
I inlayed a 3 layer piece of foil. One end fits under the bearing. Its shaped to lay inside the case up to the front of the case where its sandwiched against the boom, which is of course sanded.
On the front I did the same thing. Under the bearing to a sanded area on the boom and sandwiched. Another piece is sandwiched in that same spot and the other end goes between the boom block and frame right over one of the screw holes. The CF is sanded there and when you insert the screw that piece gets sandwiched right against the sanded CF.
Its all completely concealed. This gave me continuity from the front of the CF frame to the tail hub.
Socal500 is offline        Reply With Quote
Old 01-27-2008, 10:09 AM   #9
autopilot
thanks i'm going to to it just for piece of mind.
T-rex 450 SA
DX7 radio
GY401
T-rex 500
Old 01-27-2008, 01:26 PM   #10
Aberdeen
Said me.
Aberdeen is offline        Reply With Quote
Old 01-29-2008, 06:41 AM   #11
fugega
Here is a way to connect the two belt pulley:
You must sand hard both end of the tail boom to remove the coating and the edge of the boom end to keep from cutting the wire in the boom block.
At the end You can check the connection between the tail shaft and the front pulley with a voltmeter.
Regards
Gabor
fugega is offline        Reply With Quote
Old 01-29-2008, 06:47 AM   #12
mk1spitfire
This picture has been a long time coming.
So do you do this AND also connect from neutral bec wire to frame??
OR do one?
450 GF Blinged 65hb/401/9650-DX7
500 CF 5245/401/9257 -DX7.
MH150
CX2
mk1spitfire is offline        Reply With Quote
Old 01-29-2008, 07:32 AM   #13
fugega
Yes, the neutral also connected to the frame (at the motor mount).
Old 01-29-2008, 09:22 AM   #14
Trex mad1
Am i right in thinking if using a metal tail box just the wire at the front needs to be done
People are earthing the neg on the esc to the motor mount, what about external bec? If both the lives and the negs on the esc and bec are connected at a join then, via the lipo wire then both units will be ground to the motor mount is that ok
And is it advisable to ground the boom to the motor mount aswell, or is anywhere on the frame ok
Marcel
Trex 450se v2 Futaba 401+ 9257, Hs65mg's
Trex 500cf Futaba 502 + 9257, 9257's cyclc
Trex 600N pro Futaba 611 +251, 451's cyc/throttle, GV1
Raptor 50v2 Futaba 401 +9256, Spektrum cyclic
Trex mad1 is offline        Reply With Quote
Old 01-29-2008, 10:11 AM   #15
fugega
Now I'm using the metal tailbox too and because the boom and the tailcase anodized You have to sand the end of the boom and the inside of the case where the boom stops.
At the end check the connection with voltmeter just to be sure.
I think inside the Align ESC the battery negative connected with the BEC negative.
My frame connected to the battery negative pole.
Actually for keep the belt from static charge You don't have to connect the tail system to the frame or the battery just the two pulley to each other, but it won't hurt.
Old 01-29-2008, 10:21 AM   #16
mk1spitfire
So you are saying:-
Connect boom, both ends to front and back pulley to sort static.
optional connect ALSO to frame?
optional connect ALSO from battery NEG to frame?
MH150
CX2
Old 01-29-2008, 10:37 AM   #17
fugega
Yes, the "-" as Aberdeen says.
Edit:
Yes, exactly, at least this is how I'm think it.
Old 01-29-2008, 10:46 AM   #18
mk1spitfire
So you have TWO different earth points on the side of your frame.
1 from belt/pulley and boom to frame
2 from BEC NEG to frame
MH150
CX2
Old 01-29-2008, 10:58 AM   #19
stevehonn
What about the fibreglass frame version, the frame is an insulator so doesn't conduct - do you earth bond to the motor mount?
Steve H
Trex 600N Sport, 700N , Trex 250, Beam E4, Trex 550E, Raptor E550, Mikado Logo 500 3D, now a happy user of Futaba 10CG
stevehonn is offline        Reply With Quote
Old 01-29-2008, 11:04 AM   #20
fugega
Yes i have two points. I don't think this will cause problem.
The motor mount is connected to the black wire (-) of the deans connector on the ESC. (battery NEG)
Sorry, the picture is little confusing.
