Old 01-27-2008, 05:32 PM   #1
epc2
Default Want more Cyclic???Easy mod.
Hi Guys,
I don't know how many of you here agree with me but one thing I didn't like about the 500 was that I found the cyclic very slow and I've been thinking on how to improve cyclic speed.
Here's what I tried and liked: A set of KSJ 3mm paddles ($6) , these paddles weight 16gr , I lightened them down to 11.5g and I can tell you that the cyclic speed is now a lot faster than with the stock paddles.
epc2.
epc2 is offline        Reply With Quote
Old 01-27-2008, 05:44 PM   #2
Ensonic
Slow!! Holy Moly! I set up my AIL / ELEV / Pitch like allways, give as much as no binding results on the swash. The result was 14 degrees collective and 14.5 degrees cyclic. It was so horrible fast, that I had to limit ist to 11 degrees... Did you use wrong servos horns, that are to short?
Thx,
Yours
Henning Piez
Ensonic is offline        Reply With Quote
Old 01-27-2008, 05:56 PM   #3
epc2
Nope , proper servo arms and swash maxed out too , 13deg. of collective and 2850 H/S.
epc2.
Old 01-27-2008, 09:37 PM   #4
OICU812
Yea it is very slow indeed. I do hope they make a lighter paddle as well perhaps a tad longer flybar to speed it up.
Mikado Heli
Scorpion Motors
Western Robotics RC,
Youth Generation Electronics
OICU812 is offline        Reply With Quote
Old 01-28-2008, 03:59 AM   #5
kraaijer
Weird, I don't find it slow at all, quite the contrary, I had to tune it down, expo -30%....
Goblin 630, Vibe 50, trex 500, 450, mcpx v2 and mcpx bl. All fbl of course...:-)
kraaijer is offline        Reply With Quote
Old 01-28-2008, 04:10 AM   #6
Trex mad1
Have they got out any nice carbon ones yet to buy, read that the radix blades should be out in a month also.
Marcel
Trex 450se v2 Futaba 401+ 9257, Hs65mg's
Trex 500cf Futaba 502 + 9257, 9257's cyclc
Trex 600N pro Futaba 611 +251, 451's cyc/throttle, GV1
Raptor 50v2 Futaba 401 +9256, Spektrum cyclic
Trex mad1 is offline        Reply With Quote
Old 01-30-2008, 10:20 PM   #7
dieselracer
Cool. Where do you get them? is there an other brand this can be done to? I dont have a 500 yet. but in know the stock set up is going to be slow for me.
dieselracer is offline        Reply With Quote
Old 01-30-2008, 10:42 PM   #8
whaleboy
Hmmm... I'm just learning so I started at 25% expo on cyclic, but it was so sluggish I had to turn the expo off. Now it seems ok... not too twitchy at all. I only have @ 8 degrees swash though... or around there (tx limited), I need to measure to see what its at now.
-David
whaleboy is offline        Reply With Quote
Old 01-31-2008, 12:04 AM   #9
dieselracer
how much did the stock ones weight?
Old 01-31-2008, 10:11 AM   #10
epc2
9gr.
epc2.
Old 01-31-2008, 10:27 AM   #11
psindrup
-David
Sluggish with expo?
What throttle curve are you running?
I am running 0-60-80-90-100 and +35 expo on my DX7, and I find very responsive indeed.
Peter
100% n00b
psindrup is offline        Reply With Quote
Old 01-31-2008, 12:55 PM   #12
WiscHeli
i got wild fast +-15 with my DS3421s had to calm it down to +-10 and dial down Expo ,,, I have run to grow in thats for sure
T-Rex 450seV2,,T-Rex 500CF..T-Rex 600N-Pro..JR 9303
WiscHeli is offline        Reply With Quote
Old 01-31-2008, 03:06 PM   #13
OICU812
If they make a paddle in the 6-7 gram mark that woulod be much better for sure, it would speed up the cylic enough,,, I think....:wink:
Mikado Heli
Scorpion Motors
