Old 02-09-2014, 03:35 PM   #1
johnsonj
Default dx9 Binding Issue
Having trouble with binding a MCPX BL to my new DX9. All is good except the hell won't spool up. Throttle hold is off. Any help would be good as I'm somewhat of a newbie.
johnsonj is offline        Reply With Quote
Old 02-09-2014, 07:18 PM   #2
aerocal
Did you try lowering the throttle trim a few clicks? Possibly lower the trim all the way.
Is the throttle channel moving up and down on the Monitor screen?
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote
Old 02-09-2014, 07:23 PM   #3
JonJet
I find that if I'm within a foot or two, I have bind troubles...
Try stepping away 5-6 feet, the RF signal from the DX9 can be overwhelming
mCPX(44)*HCP100S*130X(36)*150X(7) * 180CFX(15) * 230S(2) * 250CFX * 270CFX * 300X * OXY3+
nanoQX * NanoQX3D * 180QX * DX9 * HF180060
JonJet is online now        Reply With Quote
Old 02-09-2014, 08:53 PM   #4
johnsonj
Thanks for the suggestions and by the throttle channel do you mean throttle curve screen?
Old 02-10-2014, 01:22 AM   #5
aerocal
No.Is the Thr Channel output moving on the Monitor screen?
HELIFREAK !!!
Old 02-11-2014, 04:55 PM   #6
johnsonj
Yes it is. I took it too my LHS and got some help there. I think i should have bought the dx8 as the 9 might be a bit over my head. Im sure Ill be back with other questions in the future. Thanks for the help.
Old 02-14-2014, 01:49 AM   #7
CrashyCrashy
I was getting "BIND FAILED" 15-20 times before I had one successful bind. After trying the above I get successful binding everytime!
CrashyCrashy
CrashyCrashy is offline        Reply With Quote
