Old 02-18-2014, 08:58 AM   #1
Jurica
Default Goblin 570 shown!!
Bert just posted a picture on his facebook profile 17 minutes ago! EDIT: Some people say it's a 500 competition, not sure if it's a competition or a 570? Can't really read the text well on the photo. Looks like 570 to me?
Align T-Rex 550 DFC SELLING
AccuRC
Spektrum Dx7s
Jurica is offline        Reply With Quote
Old 02-18-2014, 09:00 AM   #2
spykez
Jeepers.. Pity I'm broke lol..
Still in exile. FML.
spykez is offline        Reply With Quote
Old 02-18-2014, 09:51 AM   #3
Frostwick
It clearly says 570 on the boom!
http://www.helifreak.com/attachment....8&d=1392698732
G500, KDE-MKS-YGE-Ikon
WARP360, Scorpion-MKS-YGE-Ikon
NX4, OS37-MKS-AR7200bx
Frostwick is offline        Reply With Quote
Old 02-18-2014, 09:52 AM   #4
michael88997
looks like 570 on the boom also.. interested to see if they did anything to the frames
michael88997 is offline        Reply With Quote
Old 02-18-2014, 10:05 AM   #5
tracernz
The thread from earlier: http://www.helifreak.com/showthread.php?t=603422
Also more info/speculation: http://www.helifreak.com/showthread.php?t=601928
| Jeti DS-16 | Compass 7HV / HC3SX | SAB Goblin 500 / iKON | Align Trex 500e DFC / AR7200BX | Tarot 450 Pro DFC / iKON |
tracernz is offline        Reply With Quote
Old 02-18-2014, 11:30 AM   #6
snemi00
No more speculation, details are out:
Goblin 570
General Specifications:
Main rotor diameter: 1278 mm (with 570 mm blades)
FBL System
Main blade length: 550 to 575mm
Tail rotor diameter: 260 mm
Tail blade length: 95 mm
Main shaft diameter: 10 mm
Spindle diameter: 8 mm
Weight including electronics: 2400 g (excluding batteries).
Special feature:
Full carbon boom
Battery tray 6S and 12S
Inside carbon rod
Dampened tail system
Electronic Specifications:
Cyclic Servos: Standards size 40mm
Tail Servo: Standards size 40mm
Typical speed controller:
o6S 100A
o12S 80A
Maximum motor size: 4025 size (52 mm diameter, 56 mm height)
o6S 1000-1400 Kv
o12S 500-700 Kv
Battery compartment:
o6S 5000/5500 mAh. Max dimension 50x60x200mm
o12S 2600/3300 mAh. Max dimension 50x45x280mm
SAB Heli Division Rotorquest
snemi00 is offline        Reply With Quote
Old 02-18-2014, 11:32 AM   #7
snemi00
So for those people familiar with the Goblin 500 I can summarize the major changes.
Full sized servos
Able to work on 6s but, for hard core or more efficient performance use 12s
Works with a 4025 class motor
Takes up to 575mm blades, 570mm are standard
New landing gear with heavy duty plastic struts similar to the new ones for the 770
some other changes in the frames and tail servo mounting, more details to come.
With the very flexible gearing options there are huge abilities to use various kV motors and pack configurations
Old 02-18-2014, 11:41 AM   #8
spykez
12s with 500 (430mm) heli 6S packs x 2, maybe that's one target customer base.
What an odd blade size though.
Old 02-18-2014, 11:44 AM   #9
snemi00
You could run it with 550mm blades of course, the 570mm are just a great option for lighter disk loading.
I prefer 500mm blades on my Goblin 500, but there are many that much prefer the 520's
Old 02-18-2014, 11:49 AM   #10
mkovalcson
So let me get this straight....
This is a 570 class heli that takes up to 575mm blades.
Not to be confused with a primarily 6S 550 class heli that takes 520-556mm blades
And they are pushing 12S down a "half-size" from the typical 600-620mm size.
That's one way for SAB to sell a lot of "specialty" sized blades for a while!
From what I can tell Rotortech sells 570mm blades and Helidirect doesn't even carry that size right now.
This is all that I could find currently available.
http://centuryheli.com/products/prod...5722&pageid=20
Mark
2011' Protos 500, 2014' Logo 550SX, 2012' TDR, 2015' Protos Max V2, 2016' TDR2
2013' Jeti DS-16
mkovalcson is offline        Reply With Quote
Old 02-18-2014, 12:01 PM   #11
spykez
Heheh, SAB are trying to get me to buy a gobbler...
500 = 1 x X5 pack.
570 = 2 x protos packs.
630 = 2 x X5 packs.
Now, I was thinking I'd get a TT e700 or protos max, down the line..
arrrrggjh.. I think I'll just be happy with the X5, my head hurts!
Old 02-18-2014, 12:08 PM   #12
mkovalcson
500 = 1 x X5 pack.
630 = 2 x X5 packs.
Be happy with the smallest number you can
I've hit my limit for the time being. I'm actually one over where I think I should be.
That said I don't do much battery sharing between any of my helis.
Mark
2013' Jeti DS-16
Old 02-18-2014, 09:47 PM   #13
Dr. M
Wow! Looks just like.... a Goblin
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote
Old 02-18-2014, 10:29 PM   #14
squeely531
Pre-order at helidirect now.
squeely531 is online now        Reply With Quote
Old 02-19-2014, 12:58 PM   #15
CompleteDestruction
For $20 more you can get the 700. So why get this one?
Keep your skids up!
TEAM FLYBAR
130x, X3 Sprint, Goblin 500 ikon, Align 600 Nitro fb, Logo 600 ikon, DX7, No more money...
CompleteDestruction is offline        Reply With Quote
Old 02-19-2014, 01:05 PM   #16
BaconRaygun
Am I the only one who thinks this is a bad move by SAB?
...that is, unless they are still planning on releasing something in the 450 size range.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is online now        Reply With Quote
Old 02-19-2014, 01:53 PM   #17
seefest
450 will be out summertime. Why the bad move? The more options available to the consumer the better IMHO.
SAB's marketing plan has worked better than just about any manufacturer out there, so I'm sure they'll be OK.
GOBLIN 570 12S JIVE 120, BK CYCLIC, BK TAIL, PYRO 650, CYCLONE, SK540
GOBLIN 700 COMP HELIJIVE 120, RJX CYCLIC, BK TAIL, PYRO 750-500, CYCLONE, SK540
LOGO 600SXJIVE 120, MKS SERVOS, SK540, RT MAINS, CYCLONE TAILS
seefest is offline        Reply With Quote
Old 02-19-2014, 02:08 PM   #18
M&P_Hooligan
for 10 dollars less you can get the 500 too so maybe they are gonna change some prices around?
M&P_Hooligan is offline        Reply With Quote
Old 02-19-2014, 02:25 PM   #19
boogie12
+1 why do they need two helis in the 550 to 570 range I mean sure you can put a nice electronics system in it but that's a bit overkill for a heli in that size. I'm sure its going to be one bad ass bird.
SYNERGY N5C, XPERT 4501/2202T, VBAR NEO, ROTOR RAGE 30%, O.S.55HZ-R, TRUE GLO SYNERGY E5s Rail 626/106,Scorpion 4035 560kv,Hobbywing 100HV,Vbar NEO,Xpert 4401/2202 FUTABA T8J
AMA#979165
TEAM SYNERGY FIELD REP
XPERT TEAM PILOT
boogie12 is offline        Reply With Quote
Old 02-19-2014, 03:04 PM   #20
BaconRaygun
I didn't say its gonna put them out of business or anything, just seems like a funky size. Also, selling it as a 550 is odd, I know it will fly, but an over-sized tail is the recipe for an elevator bobble, especially on a heli of this size.
I'm just thinking out loud, I know goblin fanboys will be all over it like ants on a lollipop... my reasoning is that the 450 size is much more popular than the 550 size, though I suppose the 'why' makes sense from an engineering standpoint (the '570' is probably pretty close to the 500, just as the 630 and 700 are nearly identical).
Anyway, just an opinion, I'm not bashing them or anything... I do own a Goblin.
AMA# 977012
