Go Back   HeliFreak > R/C Helicopter Support > E-Sky Helicopters > Lama V3/V4 and Kob
Lama V3/V4 and Kob E-Sky Lama V3 and V4 and Kob
Old 02-07-2008, 04:03 PM   #1
Jason MaxAmps
Arrow The New MaxAmps 2S and 3S 800 Micro Heli packs are instock!!!!
Yes it's true! The New 2S and 3S 800 Micro Heli packs are in stock and ready for sale! These packs will fit the following Micro Heli's and will work with many others that use thes small packs: http://www.maxamps.com/products.php?cat=14
E-Flight Blade CX/CX2
E-Flight Balde CP/CP Pro
Gaui Hurricane 200
Heli-Max Axe EZ
Venom Air Corps
E-Sky Lama series
From initial testing in my V4 Lama these packs were out running the stock pack of the same capacity by almost five more minutes and they were coming out cooler than the stock pack.
Get em' now with with your favorite connector and balance tap installed and ready to go.
Jason
Jason
MaxAmps Marketing Manager
1-888-654-4450
Jason MaxAmps is offline        Reply With Quote
Old 02-07-2008, 04:13 PM   #2
huskynox
What's the lead time for a TP tap, Micro Deans connector? How do the fit in the stock tray?
500CF - 3650's, 3500G, Spartan, Stock ESC, Stock Motor, TP 6s Pro Power 2700mAh
PROTOS - 3650's, 3500G, Spartan, Scorpion 3026-880, ICE Lite 100, TP 6s Pro Power 2700mAh
600E - 8717's, 8900G, Spartan, Scorpion 4025-890, CC HV85, TP Pro Power 8s 3850mAh
Kasama Srimok - 8717HV's, 8900G, AR7100R, Spartan, YS 91SR, Hatori SB19
huskynox is offline        Reply With Quote
Old 02-07-2008, 04:20 PM   #3
Jason MaxAmps
Lead time is 24 to 72 hours right now. And which heli do you have. The pack dimensions are listed at the link in the first post.
Jason
Jason
1-888-654-4450
Old 02-07-2008, 04:31 PM   #4
huskynox
Sorry, I was questioning the fit in the CX/2. The dimensions look the same as the stock battery except for MaxAmps is about .250" longer.
The stock battery really doesn't fit that well width wise....
Old 02-07-2008, 04:48 PM   #5
Jason MaxAmps
It slide right in the the CX2.
Jason
Jason
1-888-654-4450
