Closed Thread
Old 03-05-2014, 12:14 AM   #1
HarryR
Default Got a AR 7200BX coming
Ok, I have an AR7200BX in transit to me. My Protos 500 has a Castle ESC that was installed by the previous owner who ran a different Gyro. So I now need to put it all together with the AR7200BX.
The heli has Futaba tail, Align cyclic servos, all digital, has an on board ESC that has been functioning with the Castle BEC and the Gyro. The leads have been modified as needed so I should just have to install the AR7200BX , do the mechanical and BeastX set up and I should be good to fly. The question is around the leads that need to be connected from the BEC to the AR7200. There are two leads coming from the BEC that, per the AR7200 have to get connected. That is in addition to the Throttle lead that comes from the BEC. Where should I plug those two leads from the BEC into??
HarryR is offline
Old 03-05-2014, 04:43 PM   #2
in2deep
Any port will work as long as its free. The AR7200bx uses a common bus for +/-. I'm using the same BEC and I have the leads going into Aux2 and Aux3.
Good luck, let us know if you have any issues.
Whiplash Gasser l Goblin Gasser
in2deep is offline
Closed Thread
